too lean with 60 psi ?! (fully balance engine with mugen computer)
I'm running stock cam, stock compression, Jun valve spring, port & polish, AEM cai, Mugen header-back with no cat, fully balance engine bottom, and mugen computer. I can't figure out why my spark plug is still white(lean) with my FPR set at 60 psi (vaccum hose off). can someone help me pls?!
how is the car accelerating.. does it stumble and hesitate when reving near "v-attack"... stock is somewhere in the high 50psi's i beleive.. maybe you should up the psi a bit
thanks man
...hope the problem can be solved simply by adjusting FPR.
If the spark plug is still white(lean) after running 65 psi, what kind of problem will it be?
BTW I've also heard too much fuel will hurt the engine as well. is that correct?
...hope the problem can be solved simply by adjusting FPR. If the spark plug is still white(lean) after running 65 psi, what kind of problem will it be?
if this doesnt solve it, then i really dont know. what kind of gas do you put in?
from what i am experienceing right now, too much fuel gives you this nasty pulsating idle. so you can kinda tell when you are giving it more than it wants. im sure that too much fuel hurts then engine, but i dont know exactly what will happen.
Reelizmpro
Sep 9, 2004 11:22 PM
bleedblue94
Jun 12, 2004 10:22 PM
