thinking of zex 55shot
Old Jul 27, 2003 | 04:44 PM
95gsr's Avatar
Default thinking of zex 55shot
a dry setup is one that sprays into the intake tube and a wet you have to tap into the intake manifold. am i correct? also I was thinking of going NA i will be getting toda c's resleeve my block to 84mm and a cr of 12.5:1 now will the 55shot be to much for what i will be doing and am i wasting money getting it. or will i still be able to use it the my future setup. and brfore any one starts I know that if I install a zex kit then it will not be NA.
thanks for the help
Luis
Old Jul 27, 2003 | 04:45 PM
95gsr's Avatar
Default Re: thinking of zex 55shot (95gsr)
oh this is going in a 95 gsr comp. test are 225- 230 across the board right now.
Old Jul 27, 2003 | 07:00 PM
RyanEJ8's Avatar
Toda cams will have too much overlap to get the full use out of the nitrous. N/A cams are designed with more overlap. With too much overlap you will blow some of the nitrous out the exhaust valves. Other than that, the setup should be fine with good tuning.
Old Jul 27, 2003 | 07:01 PM
95gsr's Avatar
anyone
People_Mover
Dec 14, 2008 02:16 PM
Squirtin EGsr
Jan 17, 2006 06:25 AM
AllMotorITR
Dec 13, 2001 07:43 PM
95gsr
Jun 16, 2001 07:57 PM
