is this the IAT?
Old Jul 27, 2003 | 04:41 PM
2000CX's Avatar
Default is this the IAT?
this is an 00 b16...its below the upper left hand side of the valve cover...about 4-5 inches down. i am throwing a code 10 and i found a local dealer who had one so i picked it up. is there anything i need to watch out for when changing it out? thanks in advance for any tips.
Old Jul 27, 2003 | 05:28 PM
Benny Hinn's Avatar
Default Re: is this the IAT? (2000CX)
nope.
that is the ECT.
IAT is intake air temperature. On a 00 B16 the IAT is in the intake tube.
Old Jul 27, 2003 | 06:09 PM
2000CX's Avatar
Default Re: is this the IAT? (Benny Hinn)
damn it...so much for these dealership guys (nothing personal). i told him i needed a IAC sensor and that is what he gave me. so does anyone have the part number for an IAC sensor for an 00 b16? also if anyone knows this, when you get the new IAC sensor is it just the small part that fits into the intake tube? or does it also have the wires and everything attached to it?
Old Jul 27, 2003 | 08:25 PM
Mr. Choi's Avatar
New User
looks like water temp sensor to me. whats an ect?
Old Jul 27, 2003 | 08:43 PM
skribblah's Avatar
Default Re: is this the IAT? (Mr. Choi)
Engine Coolent Temprature
Old Jul 27, 2003 | 09:22 PM
b19coupe's Avatar
That is the thermoswitch for the radaitor fans. The IAT (intake air temperature) sensor is usually white and is in the intake manifold. Or the intake tube on some Civics.
Old Jul 27, 2003 | 09:27 PM
F1Spec's Avatar
fan switch.
Old Jul 28, 2003 | 03:11 PM
AzG35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX &raquo;</TD></TR><TR><TD CLASS="quote">damn it...so much for these dealership guys (nothing personal). i told him i needed a IAC sensor and that is what he gave me. so does anyone have the part number for an IAC sensor for an 00 b16? also if anyone knows this, when you get the new IAC sensor is it just the small part that fits into the intake tube? or does it also have the wires and everything attached to it?</TD></TR></TABLE>
If you said IAC, you will not get the right part either. The IAC(V) goes on the back of the intake manifold. It controls your cold engine idle and such.
Old Jul 28, 2003 | 03:36 PM
2000CX's Avatar
Default Re: is this the IAT? (AzSi22)
i am throwing a code 10...i thought i needed the sensor that goes into the intake tube...is this not the IAT?
Old Jul 28, 2003 | 05:57 PM
Mikey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX &raquo;</TD></TR><TR><TD CLASS="quote">i am throwing a code 10...i thought i needed the sensor that goes into the intake tube...is this not the IAT?</TD></TR></TABLE>
You are right. If you don't have the intake air temperature (IAT) hooked up, you will throw code 10.
I hope this helps.
Old Jul 29, 2003 | 02:58 AM
2000CX's Avatar
Default Re: is this the IAT? (Mikey)
but what if its hooked up and STILL throwing a code 10? they can go bad right? i am getting a new one today so hopefully it will clear up some of my problems.
Old Jul 29, 2003 | 08:39 AM
AzG35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX &raquo;</TD></TR><TR><TD CLASS="quote">but what if its hooked up and STILL throwing a code 10? they can go bad right? i am getting a new one today so hopefully it will clear up some of my problems.</TD></TR></TABLE>
If its hooked up, you either had a bad sensor or bad connection somewhere.
Old Jul 29, 2003 | 12:31 PM
2000CX's Avatar
i am REALLY hoping it just went bad.
Old Jul 29, 2003 | 05:03 PM
hondasleeper's Avatar
Don't forget after you change out the sensor to reset your ECU.
ACTION JACTION
Engine Management and Tuning
May 17, 2011 03:48 PM
coolpix99
Nov 5, 2005 10:37 PM
aalb1
Mar 22, 2005 05:53 AM
ciRcuitJerk
Nov 17, 2002 07:54 PM
