question about the hood and body.
Old Jul 27, 2003 | 03:25 PM
tsjeff's Avatar
Default question about the hood and body.
I got into an accident earlier this year and I was wondering how you would fix that little hump near the windshield where the hood pops up.
can't figure out why the hood pops up near the headlight also. ( frame is off a lil) And hood is closed.
Sorry if the pictures don't work.
if pictures don't work just go to
http://www.imagestation.com/pi...2.jpg
and
http://www.imagestation.com/pi...d.jpg
Modified by d1crx at 12:39 AM 7/28/2003
Old Jul 27, 2003 | 03:49 PM
Project91CRX's Avatar
for the front. Try to loosen the bolt on the spring. THen use a flat and adjust the length of the Latch.
Old Jul 27, 2003 | 07:12 PM
Home Skillet's Avatar
Default Re: question about the hood and body. (d1crx)
For fixing the hood by the windshield, you can try getting a hood hinge from the junkyard. It might be bent.
Old Jul 27, 2003 | 11:48 PM
Vinceg99's Avatar
Default Re: question about the hood and body. (Home Skillet)
What he said above about the hood spring is probably the right way to do it but another thing did you check the rubber stoppers on both ends of your hood? Those could be down too far causing it to be up high.
Old Jul 28, 2003 | 07:50 PM
tsjeff's Avatar
Default Re: question about the hood and body. (Vinceg99)
the rubber isn't touching the headlight support so I'm just going to to try to adjust the spring.
Old Aug 5, 2003 | 05:59 PM
tsjeff's Avatar
Still can't firgure out why the hood pops up near the passenger fender. You guys have any other suggestions of what it could be?
Old Aug 5, 2003 | 06:09 PM
CimorelliCRX's Avatar
As someone said make sure the hinge isnt bent. But what I would do is make sure all 4 bolts are in the hood holding it in place, if there not one end will sit up a little higher, due to it not being down all the way. You could try to put a little bend in it, its an old school way, take like a peice of wood, put it in the middle and bned down softly, not hard enough to crease, but enough to push down just enough. A lot of parts on my car were put together that way, because the frame is off a bit.
Old Aug 6, 2003 | 09:27 AM
tsjeff's Avatar
Default Re: question about the hood and body. (CimorelliCRX)
So should I try bending the radiator support ?
Old Aug 6, 2003 | 09:46 AM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d1crx &raquo;</TD></TR><TR><TD CLASS="quote">So should I try bending the radiator support ? </TD></TR></TABLE>
No he's talking about bending the hood itself slightly.
lduque
Paint and Body
Sep 6, 2007 07:40 AM
C M S
Dec 11, 2004 03:05 PM
DOMKID
Apr 2, 2002 07:29 PM
