GSR brakes on a 96 EK
Old Jul 27, 2003 | 11:52 AM
Sukebei Oni's Avatar
Default GSR brakes on a 96 EK
i just did a five lug conversion on my teg, and now i have extra GSR brake components. how hard would it be to swap the GSR brakes onto my EK? that way i can get disk brakes in the rear. how different is the civic suspension parts from the integ?
Old Jul 27, 2003 | 01:12 PM
EK MONEY's Avatar
Default Re: GSR brakes on a 96 EK (Sukebei Oni)
uve got PM
Old Jul 27, 2003 | 01:38 PM
all stock's Avatar
Default Re: GSR brakes on a 96 EK (Peagreenhatch)
should be bolt on. i did my like a month ago. the e-brake cables are a little funny to play around with, but nothing else should matter.
Old Jul 27, 2003 | 01:51 PM
kommon_sense's Avatar
Default Re: GSR brakes on a 96 EK (all stock)
The front/rear setup should bolt right up. You will need the prop valve from a 99-00 SI, and if you have trouble adding the teg e-brake cables ,then you will need the 99-00SI e-brake cables.
Old Jul 27, 2003 | 02:11 PM
Default Re: GSR brakes on a 96 EK (kommon_sense)
by prop valve, do you mean proportioning valve? whats the purpose of getting the Si one? please explain. i wish to know more
Old Jul 31, 2003 | 04:05 PM
99civic_exSB's Avatar
Yes you have rear drums which is a different proportioning valve set up. The 99-00 Si prop valve is a plug and play piece. http://www.hparts.com for the best deal.
Old Sep 30, 2003 | 06:21 AM
chrisir19's Avatar
Default Re: GSR brakes on a 96 EK (99civic_exSB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99civic_exSB &raquo;</TD></TR><TR><TD CLASS="quote">Yes you have rear drums which is a different proportioning valve set up. The 99-00 Si prop valve is a plug and play piece. http://www.hparts.com for the best deal. </TD></TR></TABLE>
I went to the site and yeah thay had parts and most of them where for the low but didn't see a prop. valve cause i need one for my EK
Old Sep 30, 2003 | 07:27 AM
Default Re: GSR brakes on a 96 EK (chrisir19)
They sell the prop valve for the 99-00 si. i talked to them a while back about ordering one, but my rear disc setup came with the valve that I needed. They used to have an online feature where you could chat in real-time with a service rep. they should be able to look-up the part number for you for the 99-00 si brake prop valve.
Old Sep 30, 2003 | 08:18 AM
Skunk2Civic94's Avatar
im doing the front gsr brake upgrade before the holidays so i'll post a how to and the whole nine
perseverance
Dec 29, 2007 04:37 AM
trustkill
Dec 7, 2007 09:02 PM
primojoe20
Oct 22, 2007 02:20 AM
trustkill
Sep 17, 2007 03:40 PM
96Spec Ek
Suspension & Brakes
Dec 13, 2005 05:21 PM
