GSR brakes on a 96 EK
i just did a five lug conversion on my teg, and now i have extra GSR brake components. how hard would it be to swap the GSR brakes onto my EK? that way i can get disk brakes in the rear. how different is the civic suspension parts from the integ?
Re: GSR brakes on a 96 EK (Peagreenhatch)
should be bolt on. i did my like a month ago. the e-brake cables are a little funny to play around with, but nothing else should matter.
Re: GSR brakes on a 96 EK (all stock)
The front/rear setup should bolt right up. You will need the prop valve from a 99-00 SI, and if you have trouble adding the teg e-brake cables ,then you will need the 99-00SI e-brake cables.
Re: GSR brakes on a 96 EK (kommon_sense)
by prop valve, do you mean proportioning valve? whats the purpose of getting the Si one? please explain. i wish to know more
Re: GSR brakes on a 96 EK (Sukebei Oni)
Yes you have rear drums which is a different proportioning valve set up. The 99-00 Si prop valve is a plug and play piece. http://www.hparts.com for the best deal.
Re: GSR brakes on a 96 EK (99civic_exSB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99civic_exSB »</TD></TR><TR><TD CLASS="quote">Yes you have rear drums which is a different proportioning valve set up. The 99-00 Si prop valve is a plug and play piece. http://www.hparts.com for the best deal. </TD></TR></TABLE>
I went to the site and yeah thay had parts and most of them where for the low but didn't see a prop. valve cause i need one for my EK
Re: GSR brakes on a 96 EK (chrisir19)
They sell the prop valve for the 99-00 si. i talked to them a while back about ordering one, but my rear disc setup came with the valve that I needed. They used to have an online feature where you could chat in real-time with a service rep. they should be able to look-up the part number for you for the 99-00 si brake prop valve.
