Ack whats wrong??
Old Jul 27, 2003 | 11:35 AM
CarbonCreations's Avatar
Default Ack whats wrong??
<u>Clutch Problems:</u>
Sticky shifting from 2nd to 3rd/ 3rd to 4th? As in they get stuck and I have to push it in pretty hard.
Popping/knocking/grinding while aggresively shifting
Have to push the clutch in to the floor to shift.
Time for a new clutch, huh?
<u> Exhaust/Engine Problems </u>
When I jump on it I kick out a lot of black smoke. Someone told me that it may be my piston rings frying up? I do burn A LOT of oil so I think that the black smoke is due to the oil.
<u> Wheel Problem </u>
Driver front wheel has a high pitch noise coming from it... what should I look into tightening?
Old Jul 27, 2003 | 02:48 PM
Default Re: Ack whats wrong?? (CarbonCreations)
Old Jul 27, 2003 | 03:32 PM
Filliam H. Muffman's Avatar
maybe you dont got enough MTF in there. or you need to change your MTF
do you have a hydo clutch? if so, bleed the lines, and check if u got enuf fluid
Old Jul 27, 2003 | 03:37 PM
EARLdaSQUIRREL's Avatar
official honda whore
for the clutch it sounds as if you have no fluid in it, bleed the clutch and tell us how it goes after that
and if your burning oil, and its black smoke, then yes its a good chance its your piston rings
and no clue about the wheel except maybe wheel bearing or axle
eg_type_r93's Avatar
think the syncro might be the problem but not 100% sure is there a grinding noise
or does the shifter keep wanting to pop out of gear?
Old Jul 27, 2003 | 03:41 PM
Default Re: (eg_type_r93)
No, its fine once I get it in gear.
When I bought the car two years ago, the previous owner said that the clutch would probably need to be replaced in a year. So should I just go ahead and replace it or bleed the lines first?
Old Jul 27, 2003 | 03:54 PM
all stock's Avatar
clutch friction plate glazed? may need to replace it.
start with the basics...when was the last time u changed ur tranny oil?
fastrider213
Jul 31, 2007 02:59 PM
cambopheonix56
Nov 25, 2004 04:52 AM
del soler
Oct 3, 2004 06:12 AM
eL
23
Sep 21, 2004 03:40 PM
toukna
Aug 27, 2004 08:31 PM
