exhaust @ idle?
Old Jul 27, 2003 | 11:31 AM
r7's Avatar
r7
Default exhaust @ idle?
should exhaust come from the wastegate (dump) @ idle?
tial wastegate, no vaccum hooked up, looks like it's close but exhausts @ idle
Old Jul 27, 2003 | 01:41 PM
Tinker219's Avatar
Default Re: exhaust @ idle? (r7)
you have the little ring between the wastegate and the manifold????
Old Jul 27, 2003 | 02:20 PM
Burke's Avatar
Banned
Default Re: exhaust @ idle? (Tinker219)
yea mine does this too. sounds kinda cool though
Old Jul 27, 2003 | 02:53 PM
r7's Avatar
r7
yeah, i have the ring there. fit good
Old Jul 28, 2003 | 04:25 PM
r7's Avatar
r7
ttt
Old Jul 29, 2003 | 02:50 PM
r7's Avatar
r7
anyone else? waste gate is open a bit even with vaccum hooked up..
Old Jul 29, 2003 | 08:35 PM
SiR Kid's Avatar
New User
You have ISSUES. How much is making it past? Shouldn't be more than a VERY small amount. If any.
Old Jul 30, 2003 | 12:30 PM
r7's Avatar
r7
Default Re: exhaust @ idle? (SiR Kid)
it's a small amount, but i can see the valve in the waste gate isn't open exactly
Old Jul 30, 2003 | 02:05 PM
SiR Kid's Avatar
New User
Are you using a fire ring gasket or the stock Tial one? I'd get a firering gasket, pull the wastegate, and install that, making sure that the little ring that came with the Wastegate kit is installed properly, almost flush with the bottom of the wastegate.
Old Jul 30, 2003 | 02:08 PM
r7's Avatar
r7
do you have to tap that ring in, or does it just sit in?, maybe it's upside down?
where do you get that other ring?
Old Jul 30, 2003 | 02:19 PM
silverEH2's Avatar
i think ur missing the ring that fits flush inside the wastegate, having a gasket at this point wont matter.....does ur car build any boost
Old Jul 30, 2003 | 02:29 PM
r7's Avatar
r7
Default Re: exhaust @ idle? (silverEH2)
car isn't driveable yet, just noticed exaust coming from the wastegate @ idle
the ring is there, and so is the gasket, but the waste gate valve looks a bit open
craig88crx
Mar 17, 2010 07:38 AM
lo0nY
Oct 31, 2007 03:48 AM
hyabusa hunter
Jun 10, 2007 11:16 AM
wade
May 14, 2004 02:04 PM
88crxvtec
Jun 21, 2003 08:40 PM
