if u could start out with any engine for FI what would u use
Old Jul 27, 2003 | 07:04 AM
boostCreep's Avatar
Default if u could start out with any engine for FI what would u use
ok thats your question...if u could start over...with any engine what would u use...im kinda scaring myself i guess because im pickin up a car with a ls vtec and i havent really seen many people with big numbers using them
Old Jul 27, 2003 | 07:07 AM
Silverhatch's Avatar
Default Re: if u could start out with any engine for FI what would u use (boostCreep)
the ls vtec will make a ton of power and good torque if the engine is built. look on hondata.com they have a LS vtec tubro setup thats making like 640WHP.
Old Jul 27, 2003 | 07:15 AM
Pengo's Avatar
any engine? if it had to be honda i'd just keep it simple and go gsr. any any engine at all? sr20det hands down
Old Jul 27, 2003 | 04:47 PM
boostCreep's Avatar
Default Re: if u could start out with any engine for FI what would u use (Pengo)
yea this trial user stuff sux...i make a post then i hit my limit
anyway i found that dyno slip....that helps a bunch...i guess ill definatly be goin all out on this motor
Old Jul 27, 2003 | 05:03 PM
T4eg's Avatar
i would go with a sleeved gsr and just throw alot of boost it.
Old Jul 27, 2003 | 05:04 PM
Accord94DX's Avatar
h23a1
Old Jul 27, 2003 | 05:06 PM
redteg1's Avatar
Default Re: if u could start out with any engine for FI what would u use (Accord94DX)
2JZGTE
Old Jul 27, 2003 | 05:19 PM
HondaGuRu's Avatar
Default Re: if u could start out with any engine for FI what would u use (redteg1)
B20Zvtec. if you build it right.
Old Jul 27, 2003 | 05:22 PM
boostCreep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redteg1 &raquo;</TD></TR><TR><TD CLASS="quote">2JZGTE</TD></TR></TABLE>
i agree...i fully beleive this is the best motor ever built....the power capabilities are mind boggling...9 second passes without ever separating the head from the block
Old Jul 27, 2003 | 05:24 PM
TravSi's Avatar
Default Re: if u could start out with any engine for FI what would u use (HondaGuRu)
id go with a dart 1.8l or 2.0l closed deck honda block and a worked on non vtec head....the bare blocks are roughly 2500 i think and all stock components bolt to them....with a set of internals, you can make some serious power without the worries of the open deck block....someday when i have more money thats the route im going...
Trav
Old Jul 27, 2003 | 05:52 PM
hybridsol's Avatar
Default Re: if u could start out with any engine for FI what would u use (RexSiT3)
Come'on... B18B w/ B16 head. Cheap+power.
Old Jul 27, 2003 | 06:14 PM
-iLLuZioN-B18C1's Avatar
Default Re: if u could start out with any engine for FI what would u use (hybridsol)
any engine? or honda/acura engine.
Old Jul 27, 2003 | 06:23 PM
ffgeon's Avatar
Default Re: if u could start out with any engine for FI what would u use (jvithayapun)
if i was gonna go honda,built lsvtec. for my nissan, i use stock sr20det.
Old Jul 27, 2003 | 07:26 PM
ekb18c's Avatar
Old Jul 27, 2003 | 07:28 PM
88ZCRX's Avatar
Default Re: if u could start out with any engine for FI what would u use (ekb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">2JZGTE</TD></TR></TABLE>
I would have to whole heartedly agree with that one.
Old Jul 27, 2003 | 07:46 PM
Drew Peacock's Avatar
Default Re: if u could start out with any engine for FI what would u use (88ZCRX)
D16 Bi$H
Old Jul 27, 2003 | 08:22 PM
mskibbz-T's Avatar
Default Re: if u could start out with any engine for FI what would u use (turbozxi)
I'm not shooting for the stars, I would keep my resilient lil B18B, it takes beatings like a champ. I am going to get it sleeved and get a semi built head probably 6 months down the road... Basically it all boils down to $$$ for me, I don't wanna blow something I can't afford to replace
Old Jul 27, 2003 | 08:27 PM
falcongsr's Avatar
What is this crap?
Default Re: if u could start out with any engine for FI what would u use (mskibbz-T)
ws6?
Old Jul 27, 2003 | 08:28 PM
SpdFrk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord94DX &raquo;</TD></TR><TR><TD CLASS="quote">h23a1</TD></TR></TABLE>
With a HKS T51R.
Old Jul 27, 2003 | 10:10 PM
poid's Avatar
For sure
So easy to get so much power out of
Old Jul 27, 2003 | 10:16 PM
lazerus's Avatar
Default Re: if u could start out with any engine for FI what would u use (poid)
500 Ci Pro RWD Drag engine. -- whatever the hell engine they use.
Old Jul 27, 2003 | 10:28 PM
nigel's Avatar
b20vtec sleeved built. that will be fun. or...
d16z6 so you can talk **** at the races and say " you got smoked by a single cam foo!"
Old Jul 28, 2003 | 06:01 AM
CRXRageD's Avatar
Absofuckinglutely!!!
Old Jul 28, 2003 | 01:07 PM
boostCreep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">Come'on... B18B w/ B16 head. Cheap+power.</TD></TR></TABLE>
dose the b16 head flow better than a type r head?...im gonna start searching on this but the car im buyin is a ls vtec with itr internals and itr head...
:edit: ok i guess the heads are the same but the valvetrain and cams are different...nothin big if your gonna redo everythin anyway
Old Jul 28, 2003 | 01:23 PM
GSRswapandslow
Guest
Posts: n/a
http://www.steveschmidtracing.com/ssr_009.htm
that
