parts interchange questions (B-series)....
k i need several parts to finish my B18A swap in my CRX and need to know what cars/years this **** will work off of:
flywheel: any 90-00 B-series right?
clutch pressure plate: ???
starter: ???any B-series???
the rear tranny bracket can only come off a manual tranny car correct?
also i my engine didnt come with the lower half of the exhaust manifold, and i thought i read somewhere that i could use the lower portion of the Civic/CRX manifold. is that correct?
thanks in advance for your help!!! (btw im needing most of the **** above too)
90-00 years OK.Flywheel and pressure plate should be from the same type of car just so you don't run into any problems
starter any b series will work.
rear tranny bracket should be off 90-93 Integra
exhaust is best if you get headers, too much restriction on stock pipe.
You will need a clutch disc from a 1990 integra. Well if your using an old cable tranny you will at least.
Modified by 90blackcrx at 12:10 AM 7/27/2003
yes auto or 5speed just did a swap using an auto rear mount last week. The intermediate shaft is definitly different. I deffinitly also threw an Auto intermediate shaft through a Parisianne back window.
The auto and manual are different... I can get you a pic if you like... I bought the wrong one... you need a 5spd on... The 5spd doesnt lay completely flat but the auto one does.
Blaze
Blaze
I put the auto rear mount on my friend's ef and it fit perfect. All bolt holes fit perfect, and the motor fits perfect. All I can think is the 92-93 auto mount might be different. The one I used was a 90-91 mount. I had a auto 90-91 mount in my car at one point. I now have the part# I mentioned earlier. The auto one I had was a little f_cked up the schmucks at the junk yard cut the rear mount nut off the mount.
But in conclusion they may be different but they work fine.
TheShodan
Sep 21, 2017 12:45 PM
