Will Shocks from a Civic fit?
Old Jul 26, 2003 | 07:55 PM
Xumarius's Avatar
Default Will Shocks from a Civic fit?
Will shocks from a 1996 to 1999 Honda Civic fit a 94 integra? I'm wondering because I know a guy selling brand new blistien shocks for a 1996 to 1999 Honda Civic.
Old Jul 27, 2003 | 01:38 PM
crxjdmsir's Avatar
Default Re: Will Shocks from a Civic fit? (Xumarius)
I am about 95% sure that yes they are interchangable. Can someone else help verify?
Old Jul 27, 2003 | 05:32 PM
CRX Lee's Avatar
Fronts will fit, rears won't. The rears on the '96-00 Civic use a narrower and deeper lower mounting clevice at the bottom whereas the '94-01 Integra are shallower and wider. Your Intregra can use rear shocks from an '89-95 Civic but not the later car. Other than the lower mount, everything else is identical.
Unless by some chance that Bilstein uses the same rear for the '89-00 and just used spacers for the '96+ cars, you are out of luck. If is enough wider of a gap that you won't be able to stretch it open and still get the bolt to work.
Old Aug 3, 2003 | 03:51 AM
drevinder's Avatar
dammmmmmmmmm nice info
78CITYTURBO
Classic Hondas
Nov 12, 2009 04:59 PM
hugomjunior
Nov 25, 2007 08:41 AM
lsvtek
Dec 18, 2006 02:37 PM
Xumarius
Jul 27, 2003 10:48 AM
1 speedstar
Feb 11, 2002 11:14 PM
