b18c dyno numbers
Old Jul 26, 2003 | 07:11 PM
JBk24crx's Avatar
Default b18c dyno numbers
what numbers should I expect out of my B18cr with tuned cam gears, one layer headgasket skunk2 high compression valves header tech header and tuned s200 and of course intake. is 200 whp possible and what would be my comression be with the mods.
Old Jul 26, 2003 | 07:22 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: b18c dyno numbers (rub760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rub760 &raquo;</TD></TR><TR><TD CLASS="quote">what numbers should I expect out of my B18cr with tuned cam gears, one layer headgasket skunk2 high compression valves header tech header and tuned s200 and of course intake. is 200 whp possible and what would be my comression be with the mods.</TD></TR></TABLE>
Around 11.8ish:1. Possible? Yes. Likely? Not in this lifetime. You should be happy if you break 180whp.
Old Jul 26, 2003 | 07:55 PM
JCushing's Avatar
no cams no way.
its something to be proud of when you can get an internally stock b18c5 motor with cams to 200whp
Old Jul 27, 2003 | 09:08 AM
NiiS's Avatar
El Centro, w0w, I used to pass through that place all the time on my way to Glamis...Its like an oven lined with cow ****. It stinks and its eternally hot.
Sorry, lol, I just never met anyone from El Centro
Is it true they run alot of dope thru there? I know that`s a place alot of illegals pass thru, but what about the drugs?
Old Jul 29, 2003 | 06:07 PM
B00ST2nR's Avatar
it'll be hard to hit 200wHP with that setup.
Old Jul 30, 2003 | 12:49 AM
Unsung's Avatar
Default Re: b18c dyno numbers (Skunk2nR)
You should see 185 after tuning.
eddysmith2000
16
Oct 20, 2014 06:10 PM
screaminhatch
31
Jul 1, 2007 09:43 PM
Built2.0Lude
Jun 16, 2004 01:52 PM
fuck honda-tech
15
Dec 18, 2003 04:46 AM
BLK99VTECR
Sep 14, 2003 06:45 AM
