greddy kit on '00 y7 o2 sensor question
Old Jul 26, 2003 | 05:30 PM
Pfieff's Avatar
Default greddy kit on '00 y7 o2 sensor question
I know that the d16y7 has 2 o2's in the stock exhaust header and I imagine the greddy kit for the 92-95 ex(that I should be receiving anyday now) only has one hole in the DP. Any ideas on this would be greatly appreciated? If one o2 has to go, what do I need to make everything still run smoothly. Thanks,
Pfieff
Old Jul 26, 2003 | 06:09 PM
falcongsr's Avatar
What is this crap?
Default Re: greddy kit on '00 y7 o2 sensor question (Pfieffdog)
i think the second o2 sensor should be after the header and is actually after the catalytic converter and should be left alone. it will still be there after you install the kit.
Old Jul 26, 2003 | 10:55 PM
Pfieff's Avatar
ttt
Old Jul 26, 2003 | 11:02 PM
falcongsr's Avatar
What is this crap?
Default Re: (Pfieffdog)
ttt for what exactly?
Old Jul 26, 2003 | 11:35 PM
97hb's Avatar
Your gonna have to extend your second 02 and get a cat with a 02 bung at the end of it.
Old Jul 27, 2003 | 08:05 AM
Pfieff's Avatar
Default Re: (NOT EVIL falconGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOT EVIL falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">ttt for what exactly?
I was just looking to get more opinions, maybe from someone that has my setup, sorry to offend you
Old Jul 27, 2003 | 09:52 AM
scttydb411's Avatar
y7 has cat at top of header, o2 at top of manifold and below cat. you will need to get new cat. primary o2 goes at end of dp and secondary goes at outlet of cat. you need both. you will probably get bad bogging until the primary heats up. had that problem when i went from stock to dc sports 4-1 header before i went turbo. just make sure your car idles until it heats up everytime you start it or you will not get any good fueling and bogging issues until it does. when i went turbo i went custom and am using a std/hf manifold that has primary o2 in the exhaust header before turbo. no more problem with bogging at cold or warm start. i just use the sensor hole at end of dp for wideband o2 sensor tuning.
DeDonDeRosa
Sep 20, 2006 04:18 PM
EFstyle
15
Jul 24, 2006 05:16 PM
dylokjai
Nov 23, 2004 11:11 AM
EM1SiR
Nov 12, 2003 10:03 AM
blacksheep399
Jul 22, 2003 04:42 PM
