Problem with 90 CRX Si Swap???
Old Jul 26, 2003 | 11:54 AM
JDMCivicEF9's Avatar
Default Problem with 90 CRX Si Swap???
I helped a friend of mine put a D16A6 into his 90 CRX Si, but we run into a problem now. The engine rotates but won't completely start. We check everything from wiring, ground wires, vaccum lines, fuel lines, and the ECU also. ECU isn't throwing any codes at all. I'm kinda lost right now. Can anybody help us out?
Old Jul 26, 2003 | 11:57 AM
yellowcrx1991's Avatar
Default Re: Problem with 90 CRX Si Swap??? (JDMCivicEF9)
Kinda of a stupid answer to put, but do you have oil in your engine?
Old Jul 26, 2003 | 12:02 PM
Default Re: Problem with 90 CRX Si Swap??? (yellowcrx1991)
Of course I put oil in and all the other fluids that the engine requires. Could it be no spark? But I put in new spark plugs and wires.
Old Jul 26, 2003 | 12:24 PM
JOEY F.'s Avatar
hmmm... a stock d16a6 in his 91 si? Its gotta be something loose...like a ECU plug or something of the sort...double, triple check....its always something simple. Hopfully...
Old Jul 26, 2003 | 12:29 PM
Vinceg99's Avatar
Default Re: Problem with 90 CRX Si Swap??? (JOEY F.)
Well in order for anyone to help you your going to have to let us know if you have the basics IE Fuel, spark, and compression. See if you have any or all and then let us know.
Old Jul 26, 2003 | 01:29 PM
youngwon22's Avatar
did that engine even run in the first place?
Old Jul 26, 2003 | 09:02 PM
Default Re: (youngwon22)
Well it has fuel, maybe spark, but the compression I have to check on that. The motor was running before, we only needed to change the bottom end out with a used one. I torqued the head back on right. It could be something small. Its gonna be some triple checking tomorrow morning.
Old Jul 26, 2003 | 10:23 PM
youngwon22's Avatar
check your battery,,,
tr3nt133
Nov 5, 2014 03:50 PM
Pooh2TheBear
Apr 16, 2014 01:58 AM
meandino
15
Dec 17, 2008 04:03 PM
King-Kong
Apr 6, 2004 12:02 PM
rschnorenberg
Oct 8, 2002 04:28 AM
