Too much oil in the motor???????????????? help again
Old Jul 26, 2003 | 10:52 AM
Acura_I-RS's Avatar
Default Too much oil in the motor???????????????? help again
if there was too much oil in my motor, would that somehow make oil squeeze out of the turbo?? might be a stupid question, but who knows, cuz i fugur if the oil pan was too full, it would sort of block the oil coming in from the return from the turbo?? would that be a possibility??? thanks
Old Jul 26, 2003 | 11:00 AM
80884's Avatar
Default Re: Too much oil in the motor???????????????? help again (Acura_I-RS)
check the dipstick and see if it has too much oil. I don't see any hp gain from runing too much oil. so put the right ammont of oil in it and see if it still leaks. simple as that.
Old Jul 26, 2003 | 11:10 AM
Acura_I-RS's Avatar
Default Re: Too much oil in the motor???????????????? help again (80884)
well, i did check it, and there is too much in there, but i was wondering, if that could be the reason my turbo is leaking from the center section??? cuz i heard somewhere if the return gets blocked or slowed way down, that all that pressure in the turbo could push on the seals and make it leak?????
Old Jul 26, 2003 | 11:12 AM
80884's Avatar
it's like this, it has to go somewhere. Kind of like if you have to **** and have no ***. it will find another way out.
Old Jul 26, 2003 | 11:13 AM
Acura_I-RS's Avatar
yea, thats the idea i was thinking of, i guess ill try and drain some of the oil out and see what happens, i wonder if the seals are bad now though?
cuz a turbo is supposed to be a straight through design as far as the oil section goes, right?? and if oil is getting blocked up in there, it willcome out through the seals or(find a new ***). sux its about 95 outside too, but it wont stop me!!
SiBlueEG6
16
Oct 9, 2009 05:11 PM
Cee_mon
Nov 18, 2005 06:11 AM
DRKSol
Sep 17, 2005 02:35 PM
Yamzz_EG
May 18, 2003 11:38 PM
