Oil leaking from ceneter cartridge. help!
Old Jul 26, 2003 | 08:45 AM
Acura_I-RS's Avatar
Default Oil leaking from center cartridge. help!
k, i found all the oil leaks and fixed them all, and now oil is coming out from between the center cartridge, and the turbine housing, does that just mean that seal is bad??? any help is appreciated!
Modified by Acura_I-RS at 8:10 PM 7/26/2003
Old Jul 26, 2003 | 09:41 AM
Acura_I-RS's Avatar
Default Re: Oil leaking from ceneter cartridge. help! (Acura_I-RS)
before, the only place it leaked from was the oil feed flange on the turbo, so i took that off, sealed it good, and put it back on. it only leaked a tiny bit, like a 3 inch puddle after 7 mins of running. then i put the feed line and flange back on, and all of a sudden it leaks extremely bad, like a 5 inch puddle in like 30 seconds.
i was looking at the turbo, and it almost looks as though, the turbine housing like pulled away from the center section, dunno if that could happen, i made sure all the bolts were good and tighht, but it still leaked! please help
alex1320
May 13, 2013 12:34 PM
TEG777
Sep 27, 2005 02:04 PM
boostin b16
Mar 15, 2003 05:44 PM
sutrusu
Aug 25, 2002 03:15 PM
NeXtLeVeL_TyPe_R
Apr 15, 2002 10:07 PM
