can a civic use twin turbos
Dude, you could put a quad turbo on a civic if you wanted to. It would take a ton of work to get everything setup correctly and tuned right. I have seen it done on a CRX before with ZDyne and 550's and fully built and all that running about 375 whp.... But you could get that out of a T3/T4....
Twin turbo's are quite useless, and are more often used in motors such as a V6, or V8, or V12..which one turbo will boost each side of the cylinders. All it'd give you is a terribly long spool-up time....and the ability to say "I have a twin turbo civic...".
I don't know that I would say worthless. It seemed to work for Dodge's M4S concept car. (You have seen the movie "The Wraith".. right???) Twin turbo 2.2L 440 hp.
http://www.badassmopars.150m.com/M4S.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrock »</TD></TR><TR><TD CLASS="quote"> Twin turbo's are quite useless, and are more often used in motors such as a V6, or V8, or V12..which one turbo will boost each side of the cylinders. All it'd give you is a terribly long spool-up time....and the ability to say "I have a twin turbo civic...".</TD></TR></TABLE>
He's right, it's worthless...
to that. Just get a single turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowcrash »</TD></TR><TR><TD CLASS="quote">I don't know that I would say worthless. It seemed to work for Dodge's M4S concept car. (You have seen the movie "The Wraith".. right???) Twin turbo 2.2L 440 hp.
http://www.badassmopars.150m.com/M4S.html</TD></TR></TABLE>
Yeah, it worked well for them. Dodge also has millions to throw into a concept car. How many daily driven 4 cylinder cars do you see that have twin turbo's- And the twin turbo's actually pay off? I'll tell you this- Definently a lot less than you see daily driven 4 cylinder cars with single turbo's.
Actually I think PPG threw in alot of the money. Regardless, the question was wether it could be done. It obviously can be done. Is it practical? No, I agree with you there. Is it worthless? Obviously not.. if it builds boost it is not worthless, just not a very good value.
"Twin turbo's are quite useless, and are more often used in motors such as a V6, or V8, or V12..which one turbo will boost each side of the cylinders. All it'd give you is a terribly long spool-up time....and the ability to say "I have a twin turbo civic..."." - mrock
umm twin turbos have faster spool up times dude :/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowcrash »</TD></TR><TR><TD CLASS="quote">.. if it builds boost it is not worthless, just not a very good value.</TD></TR></TABLE>
u will say that till you aren't fully spooled till like 6,000rpm and have to shift after a second of full boost
I figure twin turbo applications are only good when you need to sequentially boost
... IE. huge V8's with a large turbo meant to achieve big numbers, and a smaller turbo to compensate for the lag the big turbo feels..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThE bEe GuY »</TD></TR><TR><TD CLASS="quote">In conclusion, dont do it
yep.
</TD></TR></TABLE>yep.
