NEW APEX-i VAFC-II !!!
Does anyone know where i can get tech info for the new VAFC II From Apex-i?? I know it's smaller and now it's black, but
did they change any of the functions?
Add anything new??
Is it better than the first?
If not, i can get some of you guys a sick deal on the VAFC I. IF so, i will be buying the new one!
Add anything new??
OK GUYS! I found out some things about the VAFC II
1. it has 12 point fuel correction
2. an "integrated" knock sensor
3. It now has 2 seperate programmable fuel curves
3. it comes in black and the silver / blue
thats all i know for now
anyone have real data to add to this???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patty987 »</TD></TR><TR><TD CLASS="quote">thats wierd cause they are out already, and i have them in stock. </TD></TR></TABLE>
Exactly..I have them for $340 shipped
Theres a group buy on it at group buy center...
From the descriptions it doesnt look like its got any function changes.
i guess the only diffrence is the bling factor
http://www.groupbuycenter.com/buy.aspx?id=11205
You guys noted that the VAFCII can read the knock sensor. My question does it do anything once it reads the knock sensor, other than beep "e.g. Add more fuel..change the MAPI voltage to change where the ECU reads it ignition timming and fuel to stop the knocking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_DC2 »</TD></TR><TR><TD CLASS="quote">Theres a group buy on it at group buy center...
http://www.groupbuycenter.com/buy.aspx?id=11205</TD></TR></TABLE> Read this whole thread. Theres a couple of differences between the two, and as you mentioned, the black one is blingin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patty987 »</TD></TR><TR><TD CLASS="quote">it has a 8point fuel curve and a knock sensor. </TD></TR></TABLE>
what's a knock sensor?
thanks
thanks
yeA "knock Sensor" senses the beginnings of detonation - (too much to explain that also) which is a knock or ping. I really don't think the VAFCII has any ability to do anything about it though, seeing as how it would have to retard the ignition timing. i may contact APEXi just to find out for sure. i will let you guys know
So what's the difference between the VAFC2 and SAFC2? I know one has vtec control in it but does it have everything the safc has? I've seen some people run both (?!)
