STOCK BLOCK RPMS!
Old Jul 26, 2003 | 02:22 AM
All-Motor H22A's Avatar
Default STOCK BLOCK RPMS!
Just curious, but what's the highest you Prelude owners have taken you H22A on a BONE STOCK BLOCK (with or without a built head).
I've taken mine up to 8200RPM before using a P72 GSR ECU. Nothing happened luckily.
Old Jul 26, 2003 | 02:33 AM
jc836's Avatar
Default Re: STOCK BLOCK RPMS! (All-Motor H22A)
You say 8200-is that with the stock (known to be inaccurate) tach? Also is the car a 5th gen? If the answers are yes-you never were that high. Another thing ALL 5th gens have a fuel shutoff and it is supposed to be lower than that. I have been over the 7400 indicated redline and assure you that you can hear if not feel the difference.
Old Jul 26, 2003 | 03:48 AM
EH2DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All-Motor H22A &raquo;</TD></TR><TR><TD CLASS="quote">Just curious, but what's the highest you Prelude owners have taken you H22A on a BONE STOCK BLOCK (with or without a built head).
I've taken mine up to 8200RPM before using a P72 GSR ECU. Nothing happened luckily.</TD></TR></TABLE>
and why would you want to do that?
Old Jul 26, 2003 | 04:04 AM
satan_srv's Avatar
yeah a bone stock motor would fuel cut at 7800....
There's really no point in revving it that high....most H22As peak at 6800-7000 rpms...even my built motor peaks at 7500 so what's the point of going past 8000?
Old Jul 26, 2003 | 06:12 AM
SKDRCR's Avatar
Default Re: STOCK BLOCK RPMS! (satan_srv)
I heard that the tach's are actually set about 400-500 rpm high
Old Jul 26, 2003 | 10:18 AM
rjr162's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">yeah a bone stock motor would fuel cut at 7800....
'</TD></TR></TABLE>
depends on what IM you're using.... the VEMON and STR IIRC are designed for more the 7300-9000+ range.
Old Jul 29, 2003 | 11:37 PM
EH2DX's Avatar
Default Re: STOCK BLOCK RPMS! (rjr162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">
depends on what IM you're using.... the VEMON and STR IIRC are designed for more the 7300-9000+ range. </TD></TR></TABLE>
sorry bro, but that has nothing to do with it. changing your IM will not change your fuel cut-off point.
Old Jul 29, 2003 | 11:52 PM
bad-monkey's Avatar
revving that high would mean shifting into the meaty part of the powerband on a stock motor: 5200-5500 rpms. shifting at 7600 real rpm (8000 on the tach) from 1st to 2nd puts me right at 5500 (tach) when i hit 2nd, and keeps me from lowballing it through the sweeper/chicane combos.
Old Jul 30, 2003 | 04:47 AM
Quade's Avatar
Default Re: (bad-monkey)
I have a friend of mine with an aftermarket ecu on an auto prelude vtec and his rev counter would go pat 8,000 rpm and line up with the D4 marking on the drive selection indicator. I imagine it was around 10,000 rpm. Stock block.
Old Jul 30, 2003 | 08:31 AM
prelittlelude's Avatar
Default Re: (Quade)
auto + vtec = ?? does exist, and 10,000 on a stock h22 that jus insane, ,
Old Jul 30, 2003 | 08:37 AM
sslude's Avatar
Default Re: (Quade)
10,000 rpm on sotck block.....i doubt that
Old Jul 30, 2003 | 09:11 AM
Quade's Avatar
Default Re: (sslude)
Serious.........I saw it for myself. His car ran like crazy. It's still running on the road.
kornkid21792
Sep 2, 2009 06:12 AM
cycopath
Oct 17, 2008 08:50 AM
h22sedan
Dec 17, 2006 08:34 PM
mr_carman007
Aug 27, 2006 12:44 PM
spangler
Dec 17, 2002 02:35 PM
