Realistically speaking, what would a GSR put out at the wheels with...
Old Jul 26, 2003 | 12:48 AM
fcuked's Avatar
Default Realistically speaking, what would a GSR put out at the wheels with...
OBD2 GSR, with Skunk2 intake manifold, Type R cams (e/i), JDM 4-1 header with 2.5" collector, high flow cat, 2.5" exhaust mid pipe all the way back, and an AEM CAI.
Probably a chipped ECU as well, my question is, will this get anywhere near 160 whp?
I am torn between a GSR motor and an ITR. Reason i want the GSR is, cheaper to begin with, and i can work on it as money permits, rather than dump a shitload into just buying an ITR motor...which route would you take and would a GSR with those mods or close to it make anywhere near as close to what an ITR motor would make with just intake/exhaust?
Also, would a b16 tranny make much more of a diff with the GSR motor, rather than the GSR tranny itself?
Old Jul 26, 2003 | 10:50 AM
Ninja Mike's Avatar
Default Re: Realistically speaking, what would a GSR put out at the wheels with... (Junior.)
Bump for that last question... I'd like to know as well!?!?
Old Jul 26, 2003 | 11:52 AM
skribblah's Avatar
id say about 165 untuned to the wheels.
i hate bench racing.
Old Jul 28, 2003 | 05:56 AM
Witty's Avatar
Default Re: Realistically speaking, what would a GSR put out at the wheels with... (skribblah)
Go with a B16 tranny
Old Aug 1, 2003 | 02:34 AM
K20  EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">id say about 165 untuned to the wheels.
i hate bench racing.</TD></TR></TABLE>
Ditto
Old Aug 1, 2003 | 04:26 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junior. &raquo;</TD></TR><TR><TD CLASS="quote">OBD2 GSR, with Skunk2 intake manifold, Type R cams (e/i), JDM 4-1 header with 2.5" collector, high flow cat, 2.5" exhaust mid pipe all the way back, and an AEM CAI.
no thats low for those mods, if your gsr still has good compression, you can expect to see a good 175-180hp at wheels and about 125-128 in torque. add some adj cam gears on there as well when putting in the ITR cams, if oyu need some just PM me, I have skunk2 gears and some no brand 6 bolt gears.
About 6 yrs ago my old GSR made 170+hp at wheels with cusco cam gears, iceman intake, ITR intake side camshaft and dc sports 4-2-1 header with an unorthodox crank pulley. Now a lot more better combinations are available, no reason why a stock GSR won;t top 180hp @ wheels with simple bolt-on mods, providing motor is still in good shape.
Greg
Old Aug 2, 2003 | 09:53 AM
GOLDBERG's Avatar
Default Re: Realistically speaking, what would a GSR put out at the wheels with... (CHEETAH)
dont waste money on the skunk 2 intake manifold.... power isnt that great over a stock gsr
Old Aug 4, 2003 | 09:26 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Realistically speaking, what would a GSR put out at the wheels with... (GOLDBERG)
I've seen 8whp across the board top end on a semi-mild GSR. Car was dyno tested first w/...
1995 GSR coupe
AEM CAI
DC JDM 4-1 (open)
CTR N1 crank pulley
CTR cams
AEM cam gears
PR3 pistons, O/S
AEM fpr
VAFC
173/124
Portmatched stock throttlebody to Skunk2 manifold, removed FPR/VAFC & added Hondata P28 s200.
181/124
There was no gain in TQ, however there was an 8whp gain in the top end of the graph. The previous set-up was tuned to a perfectly flat A/F curve of 12.6-12.8.
Personally I don't believe he gained it from switching to a Hondata, although it was a nice benefit to have when changing manifolds on the GSR.
slimjimdanny
Mar 31, 2007 04:46 PM
JDM_Risa
Nov 14, 2006 07:25 AM
BolivianFuego
May 13, 2006 08:33 AM
JDM SLEEP3R
Jan 5, 2006 07:54 AM
hypnoticz
Nov 8, 2001 06:26 AM
