what the hell is code 20 ??? electronic load detector???
first of all, I'd suggest doing a search, this has been covered MANY times.
but ill start ya off for code 20
https://honda-tech.com/zerothread?id=491917
https://honda-tech.com/zerothread?id=272933
https://honda-tech.com/zerothread?id=92853
https://honda-tech.com/zerothread?id=254835
https://honda-tech.com/zerothread?id=232210
my guess is that your alternator is probably bad
Modified by Hcivic88 at 7:45 PM 7/26/2003
seems u getting a code 1.,.maybe a bad O2 sensor ($35 new one)
code 4-crank angle... make saure u got it wired right and that the dizzy isnt all F%$* up
code 9- CYL sensor... it also be in the dizzy.... maybe u did rewired bad or something
code 20- ELD... when i had it , it was bc of bad grounds... i will start by grindin down to bare clean metal the GND from the batt to chassis and tranny,. valve cover ones., and thermostat one... i will do this first to make sure isnt causing the other ones also....
