Knocking, but not from the block, seemingly from the Tranny!!!!!!...?????
Old Jul 25, 2003 | 11:03 PM
DCStreetHtch's Avatar
Default Knocking, but not from the block, seemingly from the Tranny!!!!!!...?????
Well just like the title says, the knocking sounds very similar to rod knock but is not coming from the block, seemingly from the tranny??
B16 SiRII (hydro) ClutchSpecialties stage 1 and AASCO 9lb flywheel
symptoms:
after hard driving, at a stop knocking occurs. rev the engine and it follows, BUT... when i push in the clutch it goes away. after realsing the clutch it will sometimes come back and sometimes will not. Noise is best heard from tranny casing, near rear. Knocking does not occur (or possibly cannot be heard) while driving, hence in gear.
I have ruled out rod knock because of the clutch thing. i have also ruled out throw-out bearing because the noise response is opposite, it goes away when clutch is engaged.
I took it to a reputable japanese mechanic today and he says it could be the mainshaft bearing. I have found one thread in the archives where a guy pointed out the same symptons and suggested it was the mainshaft bearing but no confirmation of this being the problem?!?!?!!
https://honda-tech.com/zerothread?id=277134
My questions...
mainshaft bearing... yes/no???
how long do i have daily driving it (noticed it about two monthes ago)???
any preventive repair or maintnance that will help???
thanx in advance!!!
-Bryan-
Old Jul 26, 2003 | 04:30 PM
Default Re: Knocking, but not from the block, seemingly from the Tranny!!!!!!...????? (EGStreetHtch)
dont everybody jump on this one now!!!
-Bryan-
Old Jul 26, 2003 | 04:53 PM
Kamin's Avatar
well no matter what it is you are gonna have to pull the transmission
the first thing that came to my mind was a loose spring on the clutch disk but it could very well be a mainshaft bearing.
Old Jul 26, 2003 | 04:57 PM
TrickHonda98's Avatar
Default Re: Knocking, but not from the block, seemingly from the Tranny!!!!!!...????? (Kamin)
check your plates. maybe one of the gears is loose and is grinding or sliping off another one.
Old Jul 26, 2003 | 05:04 PM
Stupid Ass's Avatar
Default Re: Knocking, but not from the block, seemingly from the Tranny!!!!!!...????? (TrickHonda77)
Yep. Mainshaft Bearing... is your tranny leaking fluid? Mine did because some debris made a small hole in my trans.
You can drive it for a while (a few weeks) but it will start to get worse and your shifter will start popping itself out of gear...
Old Jul 26, 2003 | 05:08 PM
dwilson's Avatar
Default Re: Knocking, but not from the block, seemingly from the Tranny!!!!!!...????? (MooreVTEC)
Might be loose flywheel bolts. I had the problem, but it was more of a constant sound. Just a thought.
Old Jul 26, 2003 | 05:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
You can drive it for a while (a few weeks) but it will start to get worse and your shifter will start popping itself out of gear...</TD></TR></TABLE>
LoL.that would look funny watching your shifter move around by itself.
Old Aug 2, 2003 | 12:10 AM
00gsrBrynn's Avatar
maybe its the birdies
Old Aug 2, 2003 | 01:41 PM
92ctr's Avatar
throw-out bearing maybe
Old Apr 10, 2010 | 10:20 AM
vvinkhampraseuth's Avatar
it chould be youe flexplate bolts put have to pull the tranny out
Old Apr 10, 2010 | 11:12 AM
bazoOKA_ TOoth's Avatar
Im glad you bumped this thread bro. Im having the same problem. However, this thread has been dead for about 7yrs.
CalhounBoi
Jun 11, 2007 10:33 PM
JDMtype Eg6
Dec 16, 2006 04:53 PM
vlc92189
Jul 23, 2006 05:01 PM
BoostedsiR
May 31, 2003 05:28 PM
91HATCH
11
Jan 14, 2002 06:47 PM
