STILL can't check CELs!
Old Jul 25, 2003 | 08:41 PM
Jonathan_ED3's Avatar
Default STILL can't check CELs!
CEL stays on for about two seconds when 'on', flashes off, and then comes back on and never goes off.
It won't let me check anything....ECU never goes off even when I've got the connection jumped.
WTF could be the problem?
This is with my s200/P28. I made sure I didn't have the chip turned around the wrong way.
Old Jul 26, 2003 | 10:10 AM
Newman's Avatar
New User
Default Re: STILL can't check CELs! (Jonathan_EH)
Does it do the samething when you plug in ANY other OBD-1 ECU? Even if you plugs in a stock Civic ECU, it should work just fine. Try another OBD-1 ECU to determine whether it's the P28 w/S200 (most likely it is) or if it's the car or motor, and then go from there. If it works fine with another ECU, then you know it's your Hondata ECU and you can go from there.
Old Jul 26, 2003 | 02:32 PM
Default Re: STILL can't check CELs! (Newman)
Nope, exact same thing on a few different ecus, and I know for sure one of them is good.
Old Jul 27, 2003 | 07:25 PM
any ideas?
Old Jul 27, 2003 | 07:34 PM
ATS*VEEE's Avatar
take a pic of where you are trying to jump your ecu.
Old Jul 28, 2003 | 04:02 AM
Default Re: STILL can't check CELs! (richierich)
Guys, I'm jumping the ECU properly. I've been through this before.
Even if I wasn't, the CEL should go out after a few seconds with the key 'on', which it does not.
I leave in 4 days....I really need some help here.
Old Jul 28, 2003 | 12:51 PM
Jason kiDD's Avatar
If its only revving to 3k that means you have a dead ECU or bad EPron installed..
Old Jul 28, 2003 | 01:05 PM
Default Re: STILL can't check CELs! (Jason kiDD)
It revs over 3k...I took it up to about 6K yesterday, sounded VERY weak. No VTEC, didn't want to see if it had premature fuel cut-off...it sounded bad enough at 5K.
poison's Avatar
Bad ECU or main relay. I hope you get the problem fixed man.
Old Jul 28, 2003 | 01:07 PM
Default Re: STILL can't check CELs! (poison)
I'm praying and crossing my fingers that it's just a bad relay.
Otherwise I'll have two completely useless ECU's
Old Jul 28, 2003 | 01:09 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH &raquo;</TD></TR><TR><TD CLASS="quote">I'm praying and crossing my fingers that it's just a bad relay.
Otherwise I'll have two completely useless ECU's </TD></TR></TABLE>
Same here, I still want you to roll thru Utah and we need to meet up at least for a lil bit
Old Jul 28, 2003 | 01:16 PM
Oh yeah, for sure. I dunno if I'll have time on the way up, but if you're there around the 9-11th, we can for sure. I'll be way less pressed for time, as my friend is too anxious to see her parents again for us to stop on the way up. lol
Old Jul 28, 2003 | 02:42 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH &raquo;</TD></TR><TR><TD CLASS="quote">Oh yeah, for sure. I dunno if I'll have time on the way up, but if you're there around the 9-11th, we can for sure. I'll be way less pressed for time, as my friend is too anxious to see her parents again for us to stop on the way up. lol</TD></TR></TABLE>
So on the way back right? I'll be here on those dates. Heading over to SoCal 15-19th though.
Old Jul 28, 2003 | 02:51 PM
Jason kiDD's Avatar
Well I have a spare relay if you ever need one. Just 300 bucks for it.. hehe
Old Jul 28, 2003 | 03:42 PM
UPDATE:
ECU is fine. Plugged it into a fellow H-T members car and got no codes, started up just fine.
Plugged his ECU into MY car, and same thing. Constant CEL...never goes off.
WTF could be the problem now?
All fuses are good.
Relays maybe? If not, I've got NO CLUE wtf the problem is.
Old Jul 28, 2003 | 04:20 PM
Can the main relay still be bad even if it's clicking/priming the fuel pump?
Old Jul 28, 2003 | 04:35 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH &raquo;</TD></TR><TR><TD CLASS="quote">Can the main relay still be bad even if it's clicking/priming the fuel pump?</TD></TR></TABLE>
Ya it's possible.
Old Jul 28, 2003 | 06:55 PM
I guess the question now is if I want to buy a NEW relay, or possibly get one from a junkyard?
Old Jul 28, 2003 | 07:05 PM
poison's Avatar
Junk yard will do fine. I would swap with a friend or something though before you get another relay.
Old Jul 28, 2003 | 07:25 PM
are EF main relay's the same? I've got a friend with a few EF's, and he'll already be over here tomorrow.
Old Jul 28, 2003 | 07:33 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH &raquo;</TD></TR><TR><TD CLASS="quote">are EF main relay's the same? I've got a friend with a few EF's, and he'll already be over here tomorrow.</TD></TR></TABLE>
Ahh, I don't think so. I believe they are different.
Old Jul 28, 2003 | 07:41 PM
dangit
Old Jul 28, 2003 | 08:11 PM
fastwanabe's Avatar
Hey Jon
when you soldered in the socket are you 100% sure that no solder fell and bridged ANY connections? thats the only thing I can think of... use someone elses ECU... try the stock PO6 ecu and see if the CEL stays lit?
Old Jul 28, 2003 | 08:14 PM
poison's Avatar
Default Re: STILL can't check CELs! (fastwanabe)
Hmm, well he's tried different ECU's, could be a wiring problem that he has done, I just find it strange. I sure hope it's the main relay.
Jon, you didn't have this problem with the other motor you had in there previously right?
Old Jul 28, 2003 | 08:20 PM
Nope, and I didn't make any wiring changes that weren't already done before all of this happened.
It was all fine for I'd say a month. I had codes 41 and 36. lol.
Then it started doing this, and I just figured the ECU was fried or something, so I got the P28/hondata and it's doing the same thing. The socketing was done by Hondata and is very clean, so no problem there.
I also tried my ecu in another car, and it's fine. So it's something with my car that's the problem. I went through the wiring harness today, through anything I've done to it ever, and nothing is touching, everything is soldered nicely, and wrapped nicely.
So I dunno what the problem could be if it's not the relay. I wouldn't even have a clue as to where to look after that
