emissions failure...
Old Jul 25, 2003 | 05:33 PM
svtec's Avatar
L D E S
Default emissions failure...
my hydrocarbons @ idle were 236 ppm and the max is 220 ppm.
everything else passed easily.
is there anything i can do w/o having to mess with my exhaust.
95 gsr i/h/e---test pipe.
i would put on my stock cat, but i cant seem to find it. i think an ex-friend borrowed it a couple of years ago and he is long gone.
i just dont want to spend the money on a new cat...
i know i'm a jackass for my test pipe. i put it on 3 years ago and wish i wouldnt have...
Old Jul 25, 2003 | 05:46 PM
acuracing's Avatar
Default Re: emissions failure... (svtec)
Buy a used cat.
Old Jul 25, 2003 | 06:19 PM
svtec's Avatar
L D E S
Default Re: emissions failure... (acuracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuracing &raquo;</TD></TR><TR><TD CLASS="quote">Buy a used cat.</TD></TR></TABLE>
i knew that was coming.
Old Jul 31, 2003 | 02:45 PM
fu*kfaceC1EH2's Avatar
buy a new cat!
-even better, be a hard *** and say no to new tabs
Old Jul 31, 2003 | 04:05 PM
BigLoadChoakHard's Avatar
timing will also effect HCs try retarding ur timing before testing also if the converter is firing that will cause high levels
Old Jul 31, 2003 | 05:29 PM
acydphryck's Avatar
what he said...you MIGHT be able to find a used one at a local muffler shop...ask around...good luck
Old Aug 1, 2003 | 02:33 AM
emissions failure.... no, you mean life failure.
Old Aug 1, 2003 | 04:20 AM
EE_Chris's Avatar
Default Re: (BigLoadChoakHard)
HC's are essentially unburned fuel. Unburned fuel can come from rich a/f mixtures, evaporating fuel or improper ignition timing.
Retarding the ignition timing would basically allow LESS time for the fuel to burn...so advancing the timing should help out with HC #'s.
Leaning the a/f ratio out would also help with the #'s.
Get a catalytic converter, pronto.
Old Aug 2, 2003 | 06:25 AM
LoNslo's Avatar
Default Re: (EE_Chris)
even if you are driving w/ straight pipe all the way through??
Old Aug 2, 2003 | 10:40 AM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svtec &raquo;</TD></TR><TR><TD CLASS="quote">my hydrocarbons @ idle were 236 ppm and the max is 220 ppm.
i know i'm a jackass for my test pipe. i put it on 3 years ago and wish i wouldnt have...</TD></TR></TABLE>
high HC indicates a misfire like unburn fuel going down the exhaust. if you have a reall low o2 this will confirm a misfire at idle. a rich condition will also cause this; but, it will rise your co readings as well and lower your co2 reading. i would start to look at your spark plugs, cap, and ignition rotor for problems. most likely it's your plugs. 80% of fail HC honda and toyota's I get are because of plugs or customer just did not warmed up vehicle long enough.
blks2k3
Nov 11, 2005 04:57 PM
Tommy1223
May 30, 2005 10:12 AM
Boring
Jan 1, 2005 04:31 PM
BrandonClaps
14
Aug 7, 2003 08:21 AM
ezark
Jun 21, 2002 10:12 AM
