Those with F-Max kit, how'd you run the extra fuel line?
I have a 95 Honda Accord, and was wondering where you guys tapped into to run additional fuel for the additional injectors? I was thinking there's a little gold plug type of thing towards the drivers side of the fuel rail, and tap into that? If I were to use that as a source, what is that fitting size, and what type of fitting would be best suited?
Thanks
Thanks
You should have recieved 2 plastic T fitting with your kit. You will need to cut the fuel line between the filter and the fuel rail and T those off...then run those to the injectors...
Nextelbuddy
Jan 30, 2004 07:56 AM
doing a zex wet kit, and im wondering where the fuel line is that i need to tap already seacrhed ...
TABIAS
Nov 29, 2003 12:29 PM
