Fuel Sump to Rail Feed And Return Line Length
Re: (rip94delsol)
Sorry guys...
The fuel line kit FLK5, is designed to be use with any inline fuel pump like Bosch, Aeromotive, SX and etc.
It can be used with sump tank or welded fuel tank cover.
The kit comes complete with every fittings and adapters for your fuel pump, fuel filter (inline), fuel rail and FPR. The kit is designed to use the stock feed line as a return therefore, one less line to run and it looks a lot cleaner under the chassis.
Weld on fitting for the sump or fuel tank cover is included as well. 30 Amp relay is included as well.
I designed this kit to be a bolt on kit to where you don't need anything else to isntall the complete fuel line under your car.
The price for the -8AN line kit (popular) is $ 299 and the -10An kit is $ 329
Stan
Stan
Re: (hybrdthry911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrdthry911 »</TD></TR><TR><TD CLASS="quote">so lets say all i need is a bosche fuel pump, a sump, and an inline filter and u got the rest?</TD></TR></TABLE>
yes sir...I can get you the bosch pump, filter and you can make your own sump. I'll show you hwo I did mine and works bad *** and only cost less than $ 15
stan
stan
Re: (Flamenco-T)
-10an line for a 700+ hp would be suitable i think! if so what size would you run for a return line? kinda took out all my lines already!
Re: (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">Just run -6an line for return...</TD></TR></TABLE>
Exactly, all the Aeromotive FPR and even the Weldon FPRs(I think on Weldon) have a -6 return anyways
dominidg123
06-02-2009 05:42 PM
MarkosMotorsports
05-24-2004 06:58 PM
