Codes 71-73 and ABS light
Old Jul 25, 2003 | 03:02 PM
MooreBoost's Avatar
Default Codes 71-73 and ABS light
I took of my header, reinstalled it, all was well, I turned it on and threw codes 71-74. Cleared the ECU, reved it up again, and threw codes 71-73, no more 74, and not the ABS light is blinking code 16. I think when I sprayed off the engine bay to wash off the coolant, water may have gotten somewhere it didnt need to be. What happened? And what can I do?
gmoore
Old Jul 25, 2003 | 03:10 PM
Prelude Vtec 23's Avatar
Default Re: Codes 71-73 and ABS light (tegunderpressure)
Damn.....I had the same problem w/ my car when I rebuilt my motor and finally got it started. I keep throwing codes 71-74 (mis-firing) but every now and then it drops to just 71-72. I have yet to find out why. Have you checked your EGR? That can cause mis-firing. I check mine and it was fine, now I am going through my whole fuel system cuz that could be a reason as well. Might want to also check your distributor and plug wires.
As for the ABS light. I dont what car you have but I have searched and they said that preludes were well known for their ABS lights to come on. A couple of posts I read said that they just to "tap" the ABS unit lightly and it went away. I know that is not a good reason for you, but I did that and my light went off and has not come back on since. But again, this obviously doesnt solve the problem correctly but it worked for me.
iLUVmyACCORD
Jan 14, 2005 06:13 AM
pearlteg
Jul 6, 2004 05:32 PM
accordhybrid
Jun 2, 2003 02:37 PM
92LudeSI
May 31, 2003 12:51 AM
redteg1
Aug 18, 2001 02:42 PM
