Car won't start-90'integra ls
Old Jul 25, 2003 | 12:53 PM
b18bcivic's Avatar
Default Car won't start-90'integra ls
I've changed the pump,relay,checked fuses but still ain't getting fuel or power to the pump.What the f$#k is wrong with my car?
Old Jul 26, 2003 | 06:22 AM
b18bcivic's Avatar
Default Re: Car won't start-90'integra ls (b18bcivic)
anyone?
Old Jul 26, 2003 | 09:20 AM
real9999's Avatar
Is your ECM turning on?
Tom
Old Jul 26, 2003 | 01:56 PM
b18bcivic's Avatar
Default Re: Car won't start-90'integra ls (real9999)
yeah it is.
Old Jul 26, 2003 | 05:30 PM
4potnick's Avatar
Is the relay sending power to fuel pump? I had a problem with the wires going into the main relay under the dash.
Old Jul 28, 2003 | 08:07 AM
b18bcivic's Avatar
Default Re: Car won't start-90'integra ls (4potnick)
no the yellow/black(terminal 7) wire has no power i put power to it and the pump turns on.
Old Jul 28, 2003 | 09:08 AM
4potnick's Avatar
http://www.ultraimports.com/manuals/9093integra/ Here you go. I don't know if you have a helms manaul. It helped me find my problems!
Old Jul 28, 2003 | 12:09 PM
b18bcivic's Avatar
so what was your(potnick) problem then?
Old Jul 28, 2003 | 12:17 PM
mmuller's Avatar
Mad Scientist
have you checked your ignitor?so ur saying that the relay gives power to the pump, but the pump wont work?
Old Jul 28, 2003 | 12:27 PM
b18bcivic's Avatar
Default Re: Car won't start-90'integra ls (mmuller)
no i haven't checked the ignitor,the relay isn't giving power to the pump-when i put power to terminal 7(power wire to the pump)it turns on.
Old Jul 28, 2003 | 12:41 PM
mmuller's Avatar
Mad Scientist
did you get my pm?
Old Jul 28, 2003 | 02:00 PM
4potnick's Avatar
It was the wires going into the main relay. I guess the previous owner went yanking under the dash. Fuel gauge is still not working half the time either
Old Jul 29, 2003 | 06:56 AM
b18bcivic's Avatar
what did u do to fix it?
Old Jul 29, 2003 | 01:27 PM
b18bcivic's Avatar
could it be the oil pressure switch not letting it fire?
Old Jul 29, 2003 | 07:05 PM
mmuller's Avatar
Mad Scientist
if the relay is good it should click when you try to start the car, try to listen for it.
you sayd you changed the dizzy so thats out of the question.
as far as the oil press switch, crank the car until the oil light goes out, if it does then its ok,i will take a little while so dont worry
no_regrets
Apr 21, 2015 08:23 PM
redline1320
Apr 27, 2010 06:55 PM
Je$$eDB8
Sep 2, 2008 12:52 PM
95turboeg
Jul 7, 2006 11:38 AM
slowassciv
Mar 22, 2006 07:22 PM
