Oil Pan Help Asap
Messed up my 99 D16Y8 oil pan. Did a search to see if anythings compatible but no luck. SO im wondering if a Z6 pan will work or other D series pans, or do I need a Y8 one?
thanks.
need to buy one asap.
thanks.
i dont think the z6 nor the a6 would work on a y8... i tried a y8 pan on a z6 block. no luck and i ended up using a a6 pan on a z6 block... do a serach there are people sayin diff things.. but if the y8 pan didnt work on a z6 i doubt the z6 would work on a y8 block...
hope this helps
hope this helps
