vafc question
Old Jul 25, 2003 | 12:14 PM
crashtest Sonny's Avatar
Default vafc question
alright i installed my vafc yesterday and i cant seem to program it..i dont know what everything is when i look through it. im planning to leave everything the way it is until its tuned, but i just wanna know about vtec. how do i activate it? when i go on VTi..it says off..is it suppose to? this is hooked up to pm6 and to d16y8 engine. i hooked up the pink wire to the vtec solenoid wire which is green and yellow. i followed with these direction http://www.geocities.com/bing_....html .
what should the the L-H be..and the H-L be? for some reason i cant go lower than 5000k on the L - H. thanks.
Old Jul 25, 2003 | 01:57 PM
Default Re: vafc question (4g_civic_si)
aww someone gotta know this..and i know you guys gonna say use the search button..ive read almost all the post..but still confuse about the low-high cams..and high- low cams..
i just dont see vtec going on after the rpm
Old Jul 25, 2003 | 02:01 PM
N20B4PSI's Avatar
since you dont have a vtec ecu you will not have a vtec input signal that is what vti is . set it for vto that is vtec output from the v-afc to the solenoid.
Old Jul 25, 2003 | 02:08 PM
Default Re: vafc question (N20B4PSI)
ooO ok..how do i do that? thanks! helpful
Old Jul 28, 2003 | 02:05 PM
N20B4PSI's Avatar
You have to go in and change the monitor settings just highlight what you want to monitor and thats it.
Old Jul 28, 2003 | 02:52 PM
ok thanks..whats all that ne1 ne2 ne3..whats that?
Old Jul 29, 2003 | 10:35 AM
anyone?
TreyGSR
Oct 31, 2006 08:36 PM
wgs0023
Feb 26, 2004 03:49 AM
genetsang
Aug 20, 2003 01:54 PM
slowpokesi
26
May 1, 2003 08:35 PM
Turbo Powa
14
Apr 8, 2003 08:48 AM
