I have searched the search, and need a diy for install on power steering.
If i didnt drive my car ALL THE TIME for work and play, it would be ok! But i need to put my power steering back in and dont want to give my local shop 150 bucks to buy the parts and do it! I need to know what tools are needed and how to install just the pump and the belt and how to bleed it? thanx guys! its a 96 Vtec Prelude
its like 2 12 mm bolts to take the pump out, real cake walk, just look under the hood and you can figure it out.
As for bleeding it, no such thing, what you have to do it fill it up, start the car and turn the wheel lock to lock to get the air out, keep doing it till it is all gone
so you can access the power steering pump from opening the hood! It isnt under the car? Thanks! Hows about gettin the belt on, do i have to take the pulley off, or does it slip on with some effort or what?
you can get if off easily from under the hood, as for the belt, one of the bolts is in a slotted hole, so when you loosen it you can slide the pump down and free up the belt, no need to take the pulley off
Guest
Posts: n/a
sorry to jack your thread but im havin problems i got an h22 in my accord and i wan know how i would change my accord ps hose with a h22 hose should i cut the tips or how would i go and get my tip to mount on my h22? i have both hoses currently the accord hose is in but its just hanging there
Guest
Posts: n/a
well my accord has my h22 in it and the h22 has the power steering bracket on with the h22 pump the only thing is the hose wont fit whats the best way to get my power steering back
ive got the old accord power steering pump but i cant find the bracket and i also have an extra h22 hose whats the best way i should go on and put my ps back if i use the h22 hose then it has no places to mount as in its just dangling on the bottom of the kar... please help
Guest
Posts: n/a
its not the length thats a problem just the mounts but i hear that the 967 prelude and mount would work cuz the hose fits perfect and that if i use the accord pump the bracket is to high and it would touch the hood everytime i closed it
johnifanx98
Jan 19, 2011 11:51 AM
