Cruise control connected to ignition coil????
Old Jul 25, 2003 | 03:48 AM
Jet Black's Avatar
Default Cruise control connected to ignition coil????
Hey guys, I'm attempting to swap out the cruise from a junker 89 Ex-i into a 89 civic. But obviously the engine designs differ.
I think I can hook everything up except for the ignition coil. Its wired to the cruise control computer and I dont know why. I assume it sends out a pulse to determine RPM....problem is the accord engine doesnt turn anymore, so there is no way of telling what that pulses amplitude and frequency is.
Does anyone know what it does? Cause I need to figgure out where to splice into the divic distributor to get the same pulse.
Here is the accord cruise control diagram.
http://www.jetblack.evoluera.com/cruise.jpg
Thanks
Pierre
Old Jul 25, 2003 | 08:59 AM
Jet Black's Avatar
Default Re: Cruise control connected to ignition coil???? (Jet Black)
Dammit guys
Old Jul 25, 2003 | 09:06 AM
carolinaACCORD's Avatar
well, from the picture you posted, it is a blue wire. usually the blue wire is tach signal. I have never done this before, but I'd bet you hook it the coil negative lead.
Old Jul 25, 2003 | 09:20 AM
Jet Black's Avatar
Default Re: Cruise control connected to ignition coil???? (carolinaACCORD)
Cool thanks
Old Jul 25, 2003 | 10:47 AM
GimpyAccord's Avatar
RPM output is off the igniter on 90+ ... I'm totally clueless about the older **** tho
Old Jul 25, 2003 | 11:26 AM
Jet Black's Avatar
Default Re: Cruise control connected to ignition coil???? (GimpyAccord)
Damn
Old Jul 28, 2003 | 07:12 AM
Jet Black's Avatar
FOUND it
I think
I looked at the wire comming from the accord's coil....navy blue with grey dots, plugged into the coil with a higher guage black stripped with yellow wire.
Looked for the same pair on the civic distro...EUREKA Same pair is found on the civic distro, allthough the black stirpped with yellow is smaller. I spliced the blue wire off the civic distro...i hope its gonne work...dont wanna fry my cruise computer :D
Old Jul 28, 2003 | 03:27 PM
im_the_teacher's Avatar
here sum info.....for you
in order for cruise to work..the unit need input from rpm and mph how fast you're going.......
cruise only ativate above 25 miles (on honda)
yes, just hook that blue wire to your ignition .....
Old Jul 28, 2003 | 07:36 PM
Jet Black's Avatar
Default Re: Cruise control connected to ignition coil???? (im_the_teacher)
Thanks
I wasnt sure if the coil was beeing used to determine engine rpm....but its all good.
I'll hook it up and hope things work
Vryantec
Jul 31, 2018 03:03 PM
celavi
May 11, 2012 09:49 AM
si_motor_spt
Aug 16, 2007 05:12 AM
Dokta
Aug 7, 2002 02:51 AM
