tein ss- ride height in your car
Old Jul 25, 2003 | 02:27 AM
eg686's Avatar
Default tein ss- ride height in your car
i remember seeing a pic of a guys car where he could control the height of his car at his fingertips. the kit was made by tein. am i thinking of another kit?
Old Jul 25, 2003 | 07:16 AM
AF22's Avatar
Default Re: tein ss- ride height in your car (nocaryet)
your thinking about the right thing, but the electronic controll unit requires a tien flux setup or higher. I belive the SS is not compatiable with the control unit.
Old Jul 25, 2003 | 07:19 AM
Ya@inlinePRO's Avatar
Default Re: tein ss- ride height in your car (AF22)
the ride height? i think it just adjust the damper settings.
Old Jul 25, 2003 | 08:06 AM
shifthard's Avatar
Default Re: tein ss- ride height in your car (kwik2nec)
TEIN SS is compatible with tein EDFC
i have it on my DC2.. check site for availability
http://www.tein.com/edfc-fit.html
Modified by shifthard at 9:40 AM 7/25/2003
Old Jul 25, 2003 | 08:43 AM
B_CRUZ!'s Avatar
it does not control ride hwight.
your thinking of airbags y0!
Old Jul 25, 2003 | 08:53 AM
SloCivicHMM's Avatar
Default Re: tein ss- ride height in your car (b.cruz)
yeah its just the damper setting......works on the SS model just hood clearance issues.....
airbags are tite yo!!!
Old Jul 25, 2003 | 11:30 AM
shifthard's Avatar
Default Re: tein ss- ride height in your car (SlowCivicHmm)
hood and strut bar issue
Old Jul 25, 2003 | 12:50 PM
Civichatch2k's Avatar
The Tein Flex the the lowest kit that most people run with the EDFC which allows for the driver to adjust the dampaning force of the coilover from inside the car. Now as far as ride hieght you would be looking more into an air cylinder or something along those lines.
Old Jul 25, 2003 | 01:32 PM
awm_eg6's Avatar
the edfc wont fit on the ss for your car youd have to go with the flex's
check http://www.allworldmotorsports.com
Old Jul 25, 2003 | 02:19 PM
Default Re: (awm_eg6)
call jaydm.com good prices hooked up me and great CS.....
Old Jul 25, 2003 | 04:17 PM
eg686's Avatar
Default Re: tein ss- ride height in your car (Civichatch2k)
what is the advantage of controlling dampering force.
Old Jul 25, 2003 | 05:23 PM
nothing really...quick adjustments thats all.....for lazy people!!!
Old Jul 25, 2003 | 05:25 PM
SpooN Man's Avatar
you say that but if your on the track, the adjustments are much eaiser to read. On the fly kicks ***
Old Jul 25, 2003 | 10:30 PM
eg686's Avatar
Default Re: tein ss- ride height in your car (SpooN Man)
tein flex ride good? if so ill get the dampering thing with it.
Old Jul 25, 2003 | 10:46 PM
eg686's Avatar
i read on the tein webiste about this but i am still confused on what dampering force is and the advantages of it. i read soemthign along the lines that you can set 3 types of "road conditions" where it could suit a family, race , and driving mode. im confused.
does this EDFC give you a better ride? im confused but i very interested in the EDFC and a coil system by tein but i dont know which to get.
Old Jul 26, 2003 | 03:37 PM
92 GSR's Avatar
you need the coilovers in the car before you get a EDFC. All the EDFC does is lets you select how stiff or loose your shocks will be from inside your car. If you don't have an EDFC then you have to get out of your car and do it at each wheel inside of from inside on the fly.
Old Jul 26, 2003 | 11:47 PM
eg686's Avatar
Default Re: tein ss- ride height in your car (92 GSR)
ah thanx. i guess it would be good to invest in. is the tein flex coilovers similar to SS except that you can use the EDFC?
Old Jul 27, 2003 | 02:37 AM
the flex and ss are almost the same.....flex has stiffer spring rates and comes with the upper pillow ball mount "stock" its an option on the SS. Also I believe the Flex has one more adjustment point, perch I believe and a helper spring....
Old Jul 27, 2003 | 07:21 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Such adjustments on the fly are also illegal in many racing classes... check your rulebook...
Old Jul 27, 2003 | 01:50 PM
eg686's Avatar
Default Re: tein ss- ride height in your car (SkyeC)
hmm.. ill ahve to find out
projekt90ef
Suspension & Brakes
Aug 25, 2010 09:50 AM
VTiSoL
Sep 15, 2006 08:06 AM
PYITR821
Jun 10, 2004 11:59 AM
drunknmunkypow
31
Apr 2, 2004 11:19 AM
spoondc5
14
Aug 4, 2003 08:32 PM
