tein ss- ride height in your car
i remember seeing a pic of a guys car where he could control the height of his car at his fingertips. the kit was made by tein. am i thinking of another kit?
Re: tein ss- ride height in your car (nocaryet)
your thinking about the right thing, but the electronic controll unit requires a tien flux setup or higher. I belive the SS is not compatiable with the control unit.
Re: tein ss- ride height in your car (kwik2nec)
TEIN SS is compatible with tein EDFC
i have it on my DC2.. check site for availability
http://www.tein.com/edfc-fit.html
Modified by shifthard at 9:40 AM 7/25/2003
The Tein Flex the the lowest kit that most people run with the EDFC which allows for the driver to adjust the dampaning force of the coilover from inside the car. Now as far as ride hieght you would be looking more into an air cylinder or something along those lines.
the edfc wont fit on the ss for your car youd have to go with the flex's
check http://www.allworldmotorsports.com
i read on the tein webiste about this but i am still confused on what dampering force is and the advantages of it. i read soemthign along the lines that you can set 3 types of "road conditions" where it could suit a family, race , and driving mode. im confused.
does this EDFC give you a better ride? im confused but i very interested in the EDFC and a coil system by tein but i dont know which to get.
you need the coilovers in the car before you get a EDFC. All the EDFC does is lets you select how stiff or loose your shocks will be from inside your car. If you don't have an EDFC then you have to get out of your car and do it at each wheel inside of from inside on the fly.
Re: tein ss- ride height in your car (92 GSR)
ah thanx. i guess it would be good to invest in. is the tein flex coilovers similar to SS except that you can use the EDFC?
the flex and ss are almost the same.....flex has stiffer spring rates and comes with the upper pillow ball mount "stock" its an option on the SS. Also I believe the Flex has one more adjustment point, perch I believe and a helper spring....
PYITR821
06-10-2004 11:59 AM
drunknmunkypow
31
04-02-2004 11:19 AM
