Stripped Bolt Removers
Old Jul 24, 2003 | 10:06 PM
Agent STFU's Avatar
Default Stripped Bolt Removers
Hey guys,
Stripped a header nut. I heard about the craftsman set, what do you guys think about it? Is it good quality? The nut I stripped is only lightly rounded, I bet it would work right? Please give your feedback about this, or any similar product that I can buy early in the morning. WAIT, does Walmart carry the stripped bolt remover sets?
Old Jul 24, 2003 | 11:07 PM
91civicEX's Avatar
its called a bolt out and you can get it from sears. i had my doubts but the bolt i stripped came out super easy. i recomend it. just make sure you have an adjustable wrench or big sockets because the bolt out things are not sockets they are adapters. header bolts are 12 mm right i dont know if they have one that size.
Old Jul 24, 2003 | 11:10 PM
eh2 nihonjin's Avatar
Default Re: Stripped Bolt Removers (Syzle)
bolt out works good i had the same problem
Old Jul 24, 2003 | 11:11 PM
d0nkeyxPunch's Avatar
Banned
Default Re: Stripped Bolt Removers (eh2 nihonjin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh2 nihonjin &raquo;</TD></TR><TR><TD CLASS="quote">bolt out works good i had the same problem </TD></TR></TABLE>
lolz
Old Jul 25, 2003 | 12:44 AM
SlowazzGSR's Avatar
Default Re: (91civicLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">its called a bolt out and you can get it from sears. i had my doubts but the bolt i stripped came out super easy. i recomend it. just make sure you have an adjustable wrench or big sockets because the bolt out things are not sockets they are adapters. header bolts are 12 mm right i dont know if they have one that size.</TD></TR></TABLE>
Craftsman makes a set specifically for this purpose. They are called bolt extractors and the sets do not run cheap but omg are they quality ****. They have them at sears by the sockets. They come in a red case. You have to use a chart to figure out the size you need but i recommend buying the whole set. These extractors are really nice and who knows when youll need them again. They look exactly like a regular socket but they have waved ridges. If you need more info post what you need and Ill help out anyway I can.
Old Jul 25, 2003 | 04:17 AM
NVMYSi's Avatar
Default Re: (SlowazzGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowazzGSR &raquo;</TD></TR><TR><TD CLASS="quote">
Craftsman makes a set specifically for this purpose. They are called bolt extractors and the sets do not run cheap but omg are they quality ****. They have them at sears by the sockets. They come in a red case. You have to use a chart to figure out the size you need but i recommend buying the whole set. These extractors are really nice and who knows when youll need them again. They look exactly like a regular socket but they have waved ridges. If you need more info post what you need and Ill help out anyway I can.</TD></TR></TABLE>
I have the set he is talking about and I swear by that red case, has saved me more than once.
Old Jul 25, 2003 | 06:11 AM
Agent STFU's Avatar
Default Re: (NVMYSi)
Well thanks, Ill be looking for the red case, cuz you know what? Nearly ever damn bolt I've touch that pertains to my exhaust is either rusted all to hell, easy to strip, or seized like a ****! And I am only about half way done with all the bolts I need to remove Thanks guys! Red case, Ill go get it right now, even though I have to be at work in 20 minutes..
Old Jul 25, 2003 | 03:14 PM
Agent STFU's Avatar
Default Re: (Syzle)
I just bought the craftsman set. Needed it bad, so went to sears and paid $50 something for it. Has about 9 sockets, and a punch. Works on hand ratchets and impacts. I was a little frustrated, I had to shell out some money like that, but damn, after using this on maybe... 5, 6 bolts.. with a ratchet. I'm astounded.. I'll post a review soon, gonna try it with the impact as well.
spidermancivic
Aug 11, 2007 08:17 AM
Carnage R1
Apr 26, 2005 11:12 AM
Layziebtnh055
May 14, 2004 06:42 AM
.M.
Mar 29, 2004 10:48 AM
88 rex
Jul 24, 2003 02:18 PM
