required maintenence light
Old Jul 24, 2003 | 08:21 PM
foot's Avatar
Default required maintenence light
When I start my EP3 the maintenence required light begins to flash for about 15 seconds then stops. Did I just not notice this until today? What could be causing this?
Old Jul 24, 2003 | 08:34 PM
glw's Avatar
glw
Default Re: required maintenence light (foot)
i believe it is to let you know that you ep3 is nearing it's service interval. no worries - it will be shut off by the honda mechanic. if you want to shut it off yourself... i think holding down the odometer reset button while turning the key to on will shut it off.
someone help if i'm wrong.
Old Jul 24, 2003 | 08:44 PM
foot's Avatar
Default Re: required maintenence light (glw)
Thanks for the reply.
Old Jul 25, 2003 | 03:55 PM
foot's Avatar
I tried the odometer button, but that did not work. Any other suggestions?
Old Jul 25, 2003 | 06:59 PM
Type X's Avatar
off the top of my head its hold down the trip odometer button while the key is in than turn to accessory than crank
shut off and restart that should work
anyone verify this
i did it at like 8-10k and it should be coming up again for almost 20k
Old Jul 25, 2003 | 08:51 PM
darkvibe's Avatar
with the key out of the ignition, press and hold the odometer reset button. While holding it, turn the key to on until the maint. light stops flashing and goes off. Turn the key off.
should be all set
jhavnews
Sep 3, 2018 01:26 PM
dsm_killer
Honda S2000
Jan 12, 2007 03:58 AM
Ruskimafia
Feb 7, 2006 11:42 AM
kin_8
Honda S2000
Jul 11, 2004 04:24 AM
03ephatch
Oct 21, 2003 07:06 AM
