maintenance light up (part 2)
Old Oct 20, 2003 | 11:35 AM
03ephatch's Avatar
Default maintenance light up (part 2)
i just hit 8300 mi. and my maint light is up. weird. seems like ep owners are encountering this out of nowhere.
f1nal zero, answered in a thread.
"Ok guys here is the trick. You do have to hold down the odometer button, but the thing that most people forget to do is hold it down. Hold the odometer button down for about 5 seconds then turn the car on while still holding the odometer button down. Your check engine light will flash a few times then disappear."
did it and researched. and still left clueless, it is still on. flashes for about 5 secs and goes out. sorry to bring this thread up, but i need some assistance. much appreciated.
JDMi
Old Oct 20, 2003 | 11:47 AM
f1nal zeros's Avatar
This is what you do bro, the trick works for the type S, base, and Civic Si.
1. Insert key
2. Hold the odometer button down and keep pressed.
3. Turn key forard, but do not start it, while still holding the odometer button down.
4. Start the car, while still holding down the odometer button.
5. Maintanence required light will flash a few times then go off for good.
Old Oct 20, 2003 | 01:26 PM
Perfectionist's Avatar
Default Re: (f1nal zeros)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1nal zeros &raquo;</TD></TR><TR><TD CLASS="quote">This is what you do bro, the trick works for the type S, base, and Civic Si.
1. Insert key
5. Maintanence required light will flash a few times then go off for good.</TD></TR></TABLE>
Basically correct, but it is not necessary to start the engine. If all else fails, you could always read your owners manual. The proceedure is detailed in there.
Old Oct 20, 2003 | 01:43 PM
03ephatch's Avatar
Default Re: (Perfectionist)
flattering. how i can get a response so quick. thanx h-techies.
but... all else failed, just forgot to use my head due to procrastination . on p. 61 on ur owners manual, it will point out the solution to the affirmed problem. you don't necessarily have to start ur car. thanx again h-t
Old Oct 20, 2003 | 09:32 PM
vpforeva's Avatar
New User
Default Re: (03ephatch)
is yours just flashing and turning off after a lil bit? it doesnt stay on until 10k miles, and thats when u reset it i think
Old Oct 20, 2003 | 10:29 PM
03ephatch's Avatar
Default Re: (vpforeva)
manual says. it comes on between 8k to 10k miles.
Old Oct 21, 2003 | 07:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03ephatch &raquo;</TD></TR><TR><TD CLASS="quote">flattering. how i can get a response so quick. thanx h-techies.
but... all else failed, just forgot to use my head due to procrastination . on p. 61 on ur owners manual, it will point out the solution to the affirmed problem. you don't necessarily have to start ur car. thanx again h-t</TD></TR></TABLE>
Well, if you need to go some where starting your car would be a plus
$EP3CIVIC$
Feb 16, 2012 05:27 PM
Charlie Moua
May 2, 2008 02:11 PM
Ponis
Honda S2000
Apr 5, 2006 06:19 PM
Try2Live4God
Acura TL, RL & ZDX
Nov 30, 2005 04:21 PM
frostt3ch
Apr 4, 2004 06:06 PM
