bad oxygen sensor?
Old Jul 24, 2003 | 07:22 PM
SprayinCX's Avatar
Default bad oxygen sensor?
how can you test a o2 to actually tell if it is bad?
cause the problem i am having is:
according to my vafc at 25% - 35% or 40% car car doesn't pull, almost like it shuts off the fuel.
if i press then pedal on down to 50% or more it runs hard and great. it also works if i drop down to 20% or less throttle.
so does that sound like a bad o2?
it did throw a code 1 but if i turned the car off then back on the light goes away.(without reseting the ecu)
Old Jul 24, 2003 | 08:08 PM
prostreetonline's Avatar
Default Re: bad oxygen sensor? (SprayinCX)
Hook up an o2 gauge and check for erratic readings.
Old Jul 24, 2003 | 08:38 PM
poison's Avatar
Take a digital multimeter and verify the WHT wire goes from the O2 sensor to the D14 pinout (if it's OBD1), I believe for OBD2 it's D11. Could be wrong.
Could be a bad o2 if you have not touched anything.
Old Jul 24, 2003 | 11:10 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinCX &raquo;</TD></TR><TR><TD CLASS="quote">how can you test a o2 to actually tell if it is bad?
it did throw a code 1 but if i turned the car off then back on the light goes away.(without reseting the ecu)</TD></TR></TABLE>.
the best way is by using a scope to meassure voltage and time scale. however, a voltmeter can be used too. with engine warmed and o2 on close loop rev the motor at 2000 rpm and monitor the voltage reading - it should switch from .2 to .8 quickly not slowly. if o2 reading stays at the rich side of the scale - .5 to .9 create a vaccuum leak to how quick the o2 is responding to the leak.
well if reading is on the lean side .1 - .6 richen up the mixture . this is the reason why it is the best to do this test with a scope.
Old Jul 24, 2003 | 11:27 PM
fu*kfaceC1EH2's Avatar
Default Re: bad oxygen sensor? (HONDADNA)
anyone know what happens if there is no o2 plugged into the cat? (B18c1 OBD1 in a 95 hatch) i've been driving for a couple days without one and assuming my a/f is way off...
Old Aug 2, 2003 | 10:17 AM
HONDADNA's Avatar
Default Re: bad oxygen sensor? (fu*kface95hatch)
are we taking about the second o2 that came with obd 2 vehicle's and pre obd 2's? anyway, if your talking about the second o2 - it only monitor cat performance and the ecu/pcm also uses to perform self test. But as far as fuel mixture, I believe the ecu/pcm does not modify it. however if the primary o2 is not connected, the ecu/pcm will go into open loop and most likely it will run richer then normal..
Old Aug 2, 2003 | 10:31 AM
NonovUrbizniz's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fu*kface95hatch &raquo;</TD></TR><TR><TD CLASS="quote">anyone know what happens if there is no o2 plugged into the cat? (B18c1 OBD1 in a 95 hatch) i've been driving for a couple days without one and assuming my a/f is way off... </TD></TR></TABLE>
I have no o2 in my 93 ex... it's obd 1 and it's the only o2 I have...
It runs FINE... NO loss in gas milage... not running rough at all....
I believe the only time it truely uses it to tune the fuel is under wot... and if your car is anything like every car I've driven it performs better just above wot...
It does fine at wot too... My only downside is an irritating yellow mil.
4tika4
Jul 25, 2009 05:23 AM
PreludEst
Feb 12, 2006 02:26 PM
tianporn
Aug 10, 2004 08:37 PM
Nick7
Sep 10, 2003 08:47 PM
madhatter07
Aug 9, 2003 06:30 AM
