d15 to d16
Well i have a d15b1 motor in my car right now, and i'm gonna swap a y8 head on it, and i was wondering if there was anything interchangeable between the two heads? If not what other motors are interchangeable, like the dizzy, IM, TB ect..
Thanks....
Thanks....
If the D15B1 is a 12V (HF/STD motor, right?) a 16V head should not work. There are no valve reliefs in the pistons. If you meant a D15B2, I think most parts, except valve cover and the stuff under it, are swapable.
-Dustin
-Dustin
I would use the Y8 intake manifold, a 88-91 Si distributor (bolts up to the Y8 head), OBD0 injectors, and any 92-up D-series T/B or even a B-series one. Don't forget to remove the oil control jet in the block as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm »</TD></TR><TR><TD CLASS="quote">DX's got D15B2.
True, but the d15b1 (the Std motor) is still 16v. If it's an HF motor though, you're completely right.
