did Spoon Sports make a vtec controller
Old Jul 24, 2003 | 06:28 PM
SPOON 1's Avatar
Default did Spoon Sports make a vtec controller
hey woundering if spoon made a vtec controller for the dc2 integra I see they have one for the older integra the da and the civic but havent seen one listed for the dc2
Old Jul 24, 2003 | 06:55 PM
t's Avatar
t
No, I believe that is when they started pushing their ecu.
Old Aug 3, 2003 | 07:45 PM
db8sirg's Avatar
they did but they are hard to come by. and the only it did was controller the vtec so a lot of people got the apexi/fields v-afc.
there was a dc spoon sports on ebay and went pretty cheap like75.
Old Aug 5, 2003 | 03:19 PM
mugenracer's Avatar
you'd be better off looking for an OBD1 R-spec controller made by Data Systems, the spoon controller is just the dial/**** which you turn and the light comes on when the vtec is activated. the r-spec controller usually comes with a plug and play harness and has a digital display controller and stores 2 settings plus the stock setting.
Old Aug 5, 2003 | 04:53 PM
Spoond TEG's Avatar
Default Re: (mugenracer)
Simple Answer is YES there was a VTEC conroller made but ONLY for EG4/6, EG8/9, and EG1/2
PN 35151-EG6-00 or EG2-000 Comes with a Plug and Play Harness adapter cos is about 450 bux
Old Aug 5, 2003 | 05:13 PM
bryant's Avatar
Default Re: (Spoond TEG)
They made them for all sorts of cars. EF. EG. DC i think. DA. BB. maybe EK
Old Aug 15, 2003 | 10:37 AM
mikaleg6's Avatar
ebay.com has used ones from japandy
Old Aug 16, 2003 | 09:46 AM
S13 slide's Avatar
Default Re: (dukgen)
how much do they go for in the usa?
Old Aug 16, 2003 | 02:20 PM
Tweakmeister's Avatar
Default Re: (S13 slide)
made for OBDI
waste for several reasons, but the main reason is, you only change your Vtec on a dyno so that you can have the best power delivery. There is only ONE spot Vtec should be, and your dyno graph will show this. Any other place and you'll lose power.
ELIJAH EG-2
Southeast (Sales)
Oct 8, 2009 11:45 PM
spoon92hatch
Oct 17, 2003 07:49 AM
IntegraT
Nov 12, 2001 11:23 AM
