JDM RHD conversion??
Old Jul 24, 2003 | 05:12 PM
2k1_ITR_0736's Avatar
Default JDM RHD conversion??
i was wondering how much a pain in the *** it is to do this.
where can i get the parts
detailed instructions?
what parts are needed?
thanks in advance..
btw 91 LS
Old Jul 24, 2003 | 05:26 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: JDM RHD conversion?? (2k1_ITR_0736)
the main part is usually the welding...your front clip has to be cut off and a new one welded on basically...theres a bunch of spot welds...there was a post about this recently a few weeks ago do a search
Old Jul 24, 2003 | 05:58 PM
thrty8street's Avatar
Default Re: JDM RHD conversion?? (ciRcuitSi)
bump.
Old Jul 25, 2003 | 10:08 AM
Default Re: JDM RHD conversion?? (thrty8street)
why does the whole clip need to be welded on? why cant i change all the steering rack, the dash, the heater box, the harnesses, and the pedal tree. everything else shoud be the same. right?
Old Jul 25, 2003 | 10:28 AM
Xumarius's Avatar
Default Re: JDM RHD conversion?? (ciRcuitSi y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciRcuitSi y0! &raquo;</TD></TR><TR><TD CLASS="quote">the main part is usually the welding...your front clip has to be cut off and a new one welded on basically...theres a bunch of spot welds...there was a post about this recently a few weeks ago do a search</TD></TR></TABLE>
Are you ******* high? Cut you whole clip? No. Need a RHD whole clip? I would say yes so that you can have all that you need for it. But Weld a front clip? Wow I wonder if his local shop is bending him over the counter?
Old Jul 25, 2003 | 10:29 AM
jus f0 dekarayshunZ
Default Re: JDM RHD conversion?? (Xumarius)
well, for the sake of answering your question, and keeping it at just that, here's an overview:
1. find a complete JDM EG front clip (w/motor is highly suggested)
2. find some bodyshop who's willing to do this work for you
3. the gist of the rhd conversion for EG chassis is mainly the firewall section. You'll need to get your US EG firewall removed, and apply the JDM EG firewall and everything else RHD related (dash, pedals, MC+booster, steering column, heater/AC unit, etc). Recall how I mention getting a JDM EG front clip w/engine is highly suggested? I say that cuz you need the JDM throttle cable, as it curls around the engine bay. Usually, engine-less JDM EG clips don't have a throttlecable.
4. Wiring is next. You might have to mate a the JDM EG engine harness to your US harness somehow....or you just might have to use a complete JDM engine & cabin harness.....good luck finding a complete cabin harness tho!
Since this is an EG conversion its actually a lot less work to do in comparison to an EF chassis....since most of the work is aimed at the EG firewall and not the frame rails, like on US EF chassis. ...borrowed this from another post
Old Jul 25, 2003 | 10:39 AM
romeo619romeo's Avatar
no need to cut the frame.. just do the entire firewall area
Old Jul 25, 2003 | 05:49 PM
FritzInTN's Avatar
Default Re: JDM RHD conversion?? (romeo619romeo)
http://cgi.ebay.com/ebaymotors...9390
I had this sitting in my garage and I'd figure I would put it on ebay. It might help you out. The motor and body panels I took for my own project.
Modified by FritzInTN at 6:26 PM 7/27/2003
Old Jul 25, 2003 | 08:15 PM
prostreetonline's Avatar
We did it to a customer car:
http://www.prostreetonline.com...0.asp
Old Jul 25, 2003 | 09:45 PM
GuyInASpeedo's Avatar
good luck making it street legal.
Old Jul 25, 2003 | 09:52 PM
jus f0 dekarayshunZ
Default Re: JDM RHD conversion?? (GuyInASpeedo)
its registered as lhd..why would it not be legal
Old Jul 25, 2003 | 09:57 PM
because I'm pretty sure it'd have to be registered as RHD.
Old Jul 26, 2003 | 12:15 AM
thaiphob's Avatar
Nikon!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GuyInASpeedo &raquo;</TD></TR><TR><TD CLASS="quote">because I'm pretty sure it'd have to be registered as RHD.</TD></TR></TABLE>
are you a state ref?? if your not sure, you better make sure before you post.
Old Jul 27, 2003 | 08:46 PM
Default Re: JDM RHD conversion?? (thaiphob)
well first things first..
people. please read... ok? im tired of people making nonsense posts about eg's and 94+ tegs.
If you read, my initial post it does say 91 LS. so an eg firewall would be about as handy to me as a nun with a nice set of jugs and an *** to bounce a quarter off of.
as for the front clip.
i found one fairly cheap, complete from the shifter forward.
Now do i...
Cut it from the middle a pillar back?
swap all the parts over?
cut it at the bottom of windsheild?
or just replace the firewall, steering rack, wiring harness, dashboard, steering column, pedal tree, etc....
what is the best method.
Please speak with intellegence here. anyone who has done this ( probably not many) please help me out.
Old Jul 27, 2003 | 08:59 PM
HatchBox's Avatar
Skoobie no more...
good luck finding a nun with big ***** and is hot...i have never seen one..
*bUmP*
Old Jul 28, 2003 | 11:02 AM
HatchBox's Avatar
Skoobie no more...
Default Re: JDM RHD conversion?? (ind3ciso)
up for nick ^^^
Old Jul 30, 2003 | 02:50 PM
up top please
Old Jul 30, 2003 | 02:54 PM
AWDxBOOST's Avatar
on question....why? it seems like a waste of cash to me....like the 5 lug conversion imo
Old Aug 2, 2003 | 02:49 AM
Default Re: JDM RHD conversion?? (ls_teg)
troo waste of cash.
but im tired of seeing at least 5 normal integras that are semi hooked up in any given direction. how many are RHD?
NOT A DAMN ONE.
Old Aug 2, 2003 | 06:07 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
who freaking cares what side of the damn car the steering wheel is on
Old Aug 2, 2003 | 07:17 AM
tomn_gsr's Avatar
Default Re: JDM RHD conversion?? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">who freaking cares what side of the damn car the steering wheel is on </TD></TR></TABLE>
Old Aug 2, 2003 | 08:44 AM
HatchBox's Avatar
Skoobie no more...
Default Re: JDM RHD conversion?? (tomn_gsr)
is it your car? no he was just asking how hard it would be to do and what was involved...i didnt see where he asked what u thought about the rhd conversion
Old Aug 2, 2003 | 09:52 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">is it your car? no he was just asking how hard it would be to do and what was involved...i didnt see where he asked what u thought about the rhd conversion </TD></TR></TABLE>
yeah well look what he said right here:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k1_ITR_0736 &raquo;</TD></TR><TR><TD CLASS="quote">troo waste of cash.
NOT A DAMN ONE.</TD></TR></TABLE>
he said right there it's a waste of money, but his justification for doing it is just because he never sees them. That's why I said who cares what side of the car the steering wheel is on. We drive on the right side of the road anyway, so the wheel needs to stay on the left.
Old Aug 11, 2003 | 12:53 PM
ahh **** all that LHD drive ****.
rhd is the bizzzomb
ind3ciso holdin it down for me, tanx mang.
Old Aug 11, 2003 | 02:47 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k1_ITR_0736 &raquo;</TD></TR><TR><TD CLASS="quote">ind3ciso holdin it down for me, tanx mang.</TD></TR></TABLE>
bummp
