Valve/piston clearence problems?
I'm getting a motor from a fellow h-t'er and I started to wonder if I'll run into any problems with the pistons slapping the valves. The setup is:
JDM b16a with stock bottom end
jun IIIs and complete ITR valvetrain
head milled .030 and a 1 layer headgasket
I was thinking about maybe pulling the head and adding at least a 2 layer hg. Will I be OK or should I go ahead and do it while the motor is out of the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skeletor »</TD></TR><TR><TD CLASS="quote">
head milled .030 and a 1 layer headgasket</TD></TR></TABLE>
that combonation is the problem right there...
So I should go ahead and change the head gasket? The motor has JUN cam gears so I guess they're useless. I think the JDM B16 pistons are kinda flat, that's why I thought I might not run into any problems.
275Performance
Apr 26, 2005 03:05 PM
flybert
15
Nov 15, 2004 02:26 PM
kKdARIAN
Nov 4, 2003 08:02 AM
Skeletor
Aug 5, 2003 06:14 PM
to me
