Check engine light on
Old Jul 24, 2003 | 03:58 PM
sytema's Avatar
Default Check engine light on
Does anyone here knows how to check the check engine light.. if its the same as the 98 DC2 etc...i just got my car fix on the body shop.. and i saw the check engine light on.. but i don't know how to check it.. if anyone can help me about it...
thanx for all the help, keep it up
Old Jul 24, 2003 | 07:01 PM
darkvibe's Avatar
You'll need an OBD-II reader. No using a paper clip on an EP3 or DC5...
I got one at autozone for about $150. There are some cheaper ones out there.
Old Jul 24, 2003 | 10:13 PM
Jun DC5's Avatar
Actually there is a method to checking the CEL codes by using a paper clip and counting some blinking lights, but I forget...
Old Jul 25, 2003 | 02:01 PM
darkvibe's Avatar
Default Re: (Jun DC5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jun DC5 &raquo;</TD></TR><TR><TD CLASS="quote">Actually there is a method to checking the CEL codes by using a paper clip and counting some blinking lights, but I forget...</TD></TR></TABLE>
Hmm, there used to be on old cars. But on an OBD-II system? I don't think there is. Let me know if you figure it out.
Old Jul 26, 2003 | 02:21 PM
acuratech's Avatar
Default Re: (darkvibe)
One of the pins in the data link connector can be grounded, and it will flash just like the older hondas with the paperclip. It is called SCS mode. I dont know what pin it is though...
Old Jul 27, 2003 | 02:10 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (acuratech)
Is there a serivce connecter or the 01+ cars? If so jump it. That's how you do every other honda from about 88-00.
Old Jul 28, 2003 | 06:31 PM
sytema's Avatar
Default Re: Check engine light on (sytema)
ok guys, i will take it to my friend that works as a mechanic on Acura.... maybe he could fix that for me
Old Oct 19, 2003 | 11:26 AM
2camsaam's Avatar
It is not true that you cannot check the CEL on an OBDII car because in the ear 2000 OBD was in the Civics. I recall checking the CEL on a 2000EX successfully. Do you mean that EP3 chassis do not allow this method of checking codes?
Old Oct 19, 2003 | 03:59 PM
solo2slocivic's Avatar
Default Re: Check engine light on (2camsaam)
it can still be done just that there is no scs connector on 01+ civics
Jump pin#1(BRN) to pin#12(BLK) at the 16pin dlc connector....
Old Oct 20, 2003 | 11:26 AM
CHILIBEANZ's Avatar
it's pin#1 on the left row to the 4th pin up on the right. that's the way to do it in a dc5
NewEra
Jul 20, 2009 08:13 PM
97accord_R
Apr 10, 2008 08:34 AM
egturbolsvtec
Mar 15, 2006 03:20 PM
Yak BallZ
10
Jul 25, 2005 10:05 PM
Prisky
May 4, 2005 10:22 PM
