running a little bit hot
car runs fine even with my headgasket leaking but when i let it sit still idle sometimes (its on and off i dunno wtf) it gets too hot. other times the fan will kick on and it will be back to normal other times not. i replaced the thermostat and the temp sending unit. maybe the thermostat is sticking???? any suggestions???
thanks cliff
thanks cliff
i would change the thermostat and check and i believe there is an internal thermostat switch somewhere in the area of the housing there....
if the fan is acting up, i would definetly check that. how are the fins on your radiator? are they all bent up?
sorry i couldnt be more help on the switch....
if the fan is acting up, i would definetly check that. how are the fins on your radiator? are they all bent up?sorry i couldnt be more help on the switch....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCIVICHATCH92 »</TD></TR><TR><TD CLASS="quote">THATS COOL DAWG MAYBE U SHOULD GET A HIGHER THEMOSTAT AND SEE IF THAT HELPS
Don't you mean a lower thermostat? One that opens at a higher temp would just make the problem worse.
</TD></TR></TABLE>Don't you mean a lower thermostat? One that opens at a higher temp would just make the problem worse.
how longs it been sicne you flushed your coolant? It helped me, did it a week or so ago. My old coolant was nasty as hell. So i bought some of the zerex brand coolant flush. Just went by the intructions, and put new coolant/water in.
Runs cooler now...
Runs cooler now...
Jamie Steadman
Aug 14, 2015 12:07 PM
