Will JDM B16 motor past smog with basic mods?
Old Jul 24, 2003 | 03:30 PM
hmongdude's Avatar
Default Will JDM B16 motor past smog with basic mods?
As the topic says......... Does anyone know anywhere in the central vally that does smog under the table.................
Old Jul 24, 2003 | 03:46 PM
Wicked_CRX's Avatar
Default Re: Will JDM B16 motor past smog with basic mods? (hmongdude)
Your gonna have some problems with smog since this new dyno smog started on July 1st. I was luck enough to get my car illegally smogged on June 30! As long as your parts are 50 state legal and someone is easy on the visual you "might" be okay, but who can tell with this new smog crap in Cali.. Remember though a JDM motor isn't from the US so I don't think you can even make it legit, cause the rep can't trace the serial number to make sure it's not stolen. Hope I helped
Old Jul 24, 2003 | 04:24 PM
APEX CRX's Avatar
Default Re: Will JDM B16 motor past smog with basic mods? (Wicked_CRX)
i've heard really different stories on JDM motors. I recently read in Sport Compact that as long as the JDM has an equivalent here like a B18c1/GSR and it has all U.S. emissions stuff on it it will pass smog and referee. A B16a1 will not since it was never sold here. I'm trying to figure out how to swap a JDM B1bc5 type r motor into my crx and keep it legit. anybody else knows if the above is true?
Old Jul 25, 2003 | 07:08 AM
92lsr's Avatar
Default Re: Will JDM B16 motor past smog with basic mods? (APEX CRX)
you are right and wrong , a jdm motor can pass a ref if all us smog and intake and exhaust mainfolds are hook up, the crx can be reffed but must be wired up for obd1 and the the motor can be consider a us del sol b16 motor
Old Jul 25, 2003 | 07:43 AM
MAV3RiCK478's Avatar
talk to the smog ref inyour area, they'll tell you everything you need to know. i asked the smog ref here and he said as long as the engine has been released in the US then it will pass with all the emission equipment hooked up, ie. B16a, B18c, B18c5. sorry people no ZC or B16b. and it has to be same year or newer of your stock engine.
BTW, the b18c5 has to be wired OBD2, since that's what it is.
Old Jul 31, 2003 | 10:24 AM
hmongdude's Avatar
ttt
Old Jul 31, 2003 | 01:45 PM
Lord Helmet's Avatar
Default Re: Will JDM B16 motor past smog with basic mods? (MAV3RiCK478)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAV3RiCK478 &raquo;</TD></TR><TR><TD CLASS="quote">talk to the smog ref inyour area, they'll tell you everything you need to know. i asked the smog ref here and he said as long as the engine has been released in the US then it will pass with all the emission equipment hooked up, ie. B16a, B18c, B18c5. sorry people no ZC or B16b. and it has to be same year or newer of your stock engine.
BTW, the b18c5 has to be wired OBD2, since that's what it is.</TD></TR></TABLE>
you took the words out of my mouth btw it also depends on the smog ref too. some will fail you and some will pass you, it all depends on how the smog ref interpret the smog laws.
Old Jul 31, 2003 | 05:25 PM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongdude &raquo;</TD></TR><TR><TD CLASS="quote">As the topic says......... Does anyone know anywhere in the central vally that does smog under the table.................</TD></TR></TABLE>
that's a hard question to give a definite answer to...have you tried to search for this topic at all??? i know it's been covered extensively in the past in the EG forum...try searching through the 'archived' topics under 'smog laws' or something. hope this helps out...good luck
Old Jul 31, 2003 | 05:34 PM
Patch's Avatar
Default Re: Will JDM B16 motor past smog with basic mods? (acydphryck)
I tried getting mine to pass last month, and I had double the hydrocarbon limit. Everything else I just cleared.
Old Jul 31, 2003 | 07:03 PM
KRiS1's Avatar
What is involved with the new test?
Old Jul 31, 2003 | 07:06 PM
sleeperls93's Avatar
I also heard that the motor can't be from an older car.
This is my first post on H-T!
Old Jul 31, 2003 | 07:26 PM
tianracerx's Avatar
yo i live in new jersey and my crx b16a passed and mah friend zc passed too with no problems depends on the state. but ima say find a private inspection place like a shop and throw them a couple of bucksliek 75-100 tellt hem you need a sticker they will get ya mostly italian owned shops do it.... good luck
Old Apr 5, 2005 | 09:04 AM
TallAssFilipino's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">i've heard really different stories on JDM motors. I recently read in Sport Compact that as long as the JDM has an equivalent here like a B18c1/GSR and it has all U.S. emissions stuff on it it will pass smog and referee. A B16a1 will not since it was never sold here. I'm trying to figure out how to swap a JDM B1bc5 type r motor into my crx and keep it legit. anybody else knows if the above is true?</TD></TR></TABLE>
The engine codes you're stating are already USDM if they end with numbers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperls93 &raquo;</TD></TR><TR><TD CLASS="quote">I also heard that the motor can't be from an older car.
This is my first post on H-T!</TD></TR></TABLE>
If the motor is older than your car but the same version of that motor existed in the year of your vehicle and that version motor remained unchanged, then yes you can have a 92 engine in a 93 chassis.
guamie
Nov 2, 2006 08:50 PM
trix are for kids
Jun 4, 2002 09:09 AM
YellowCivic95
Apr 25, 2002 12:01 PM
YellowCivic95
Apr 18, 2002 06:13 PM
2.2
Aug 16, 2001 03:56 PM
