srr or spc lca's ?
Old Jul 24, 2003 | 02:44 PM
xjoe's Avatar
Default srr or spc lca's ?
since i need a new rear lca, ive decided that i might as well go with an aftermarket, and am wondering which ones to go with. i know that srr does not make them for ef's, but i have read somewhere that the eg ones fit fine.
also, i heard the spc ones correct camber?
basically, im just wondering if the srr ones will fit and what i should expect to pay for either set.
TIA
Old Jul 24, 2003 | 02:48 PM
Jaker's Avatar
Default Re: srr or spc lca's ? (xjoe)
Consider a set of these as well:
http://store.hybridgarage.com/...0007B
Old Jul 24, 2003 | 03:20 PM
xjoe's Avatar
anyone have any experience with any of these? im not looking for much from them, im only buying them because i need a new one/ new bushings for the other side and it just makes more sense to buy something better
Old Jul 24, 2003 | 06:11 PM
xjoe's Avatar
the main thing im trying to figure out is if the srr ones will <U>definately</U> work, otherwise i think im going to go the spc route
thanks
Old Jul 24, 2003 | 09:08 PM
redEFnine's Avatar
if you're so unsure about the srr eg lca's fitting your ef then look up the part numbers for the spc lca's (as they make them for both the eg and ef civic's) and if they are the same i wouldn't see why you couldn't use srr eg lca's
Old Jul 24, 2003 | 11:18 PM
nautica_t's Avatar
Default Re: (redEFnine)
KSR has SRR on his ef.
so i'm assuming if he has them they will fit.
since it is on an ef
Old Jul 25, 2003 | 09:30 AM
CRXRageD's Avatar
Default Re: (nautica_t)
ew they use poly urethane. nothing like binding to make your spin out.
Old Jul 25, 2003 | 09:35 AM
projecthybrid04's Avatar
Default Re: srr or spc lca's ? (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">Consider a set of these as well:
Anyone have a set of these on there ef? how do u like it?
Old Jul 25, 2003 | 10:03 AM
Nate Dizzog
Guest
Posts: n/a
Default Re: srr or spc lca's ? (projecthybrid04)
whooa looks nice
Old Jul 25, 2003 | 05:28 PM
xjoe's Avatar
Default Re: srr or spc lca's ? (Nate Dizzog)
so no definates on the srr's? guess ill be going with the function7's
Old Jul 25, 2003 | 06:11 PM
xjoe's Avatar
i was just about to order the function7's, and it says 179.99(each) on the site, and i looked pretty carefully through the page, but i didnt see the word "pair" anywhere, guess ill just wait 'til tomorrow to call, as i dont want to pay 360 bucks for control arms
Old Jul 25, 2003 | 06:24 PM
Jaker's Avatar
Definitely a pair!
Old Jul 25, 2003 | 09:00 PM
qcoffey's Avatar
Just to try to help a little I installed a set of EG control arms in my '88 Civic Hatch. I couldn't find any '89-91 EF's in the junkyard that were clean enough where I could get the control arms off by hand. I found a '95 Civic hatch and yanked them off. They fit perfectly in my car. So there you go, EG lower control arms fit the EF's. Also, 94-01 Integra control arms will work.
Old Jul 26, 2003 | 01:36 PM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default Re: srr or spc lca's ? (qcoffey)
did you get a chance to measure the length to make sure they're similar, if not identicle? i guess i should try to find a local EF and test fit.
Old Jul 27, 2003 | 05:33 PM
xjoe's Avatar
just an update for anyone who cares, just gonna order the srr's, and hope they fit, ive had a number of people tell me they will, but nobody who actually has the srr's on their car, i do however know that ef's and eg's use the same rear strut, so hopefully everything matches up, i'll let you know how it turns out incase anyone else was going to go this route
Old Jul 27, 2003 | 08:08 PM
KS-R's Avatar
As quoted by Nautica. We have the SRR EG LCA on our CRX. So... YES, they do fit.
Old Jul 27, 2003 | 09:41 PM
ExospeedAMcrx's Avatar
Default Re: srr or spc lca's ? (KS-R)
We sell both the SPC and the SRR. The SPC for sure will change camber and provide additional wheel clearance.
http://www.exospeed.com
Wil
Old Jun 19, 2004 | 09:39 AM
SpeedMonkeyRacing's Avatar
Default Re: srr or spc lca's ? (exospeedAMcrx)
there....to those who thinks eg one won't fit ef
We're having a sale on thoes too
Jeff-
Old Jun 19, 2004 | 11:24 AM
crxgator's Avatar
Default Re: srr or spc lca's ? (JustJeff)
i bought stock honda ones for mine...$120 a pair from majestic online...
Jdmkdmkid
Suspension & Brakes
May 14, 2013 02:40 AM
turboblack2door
Jul 24, 2008 10:25 AM
chitown_ef9si
11
Aug 2, 2006 12:40 PM
ceLtic*
12
May 6, 2005 02:29 PM
Black HB
Jul 6, 2002 10:59 AM
