alignment and camber ??
Old Jul 24, 2003 | 02:35 PM
HUBB's Avatar
Default alignment and camber ??
OK im plannig to swap out my steelies for some rotas and tires real soon. my question is.....should i get a camber kit or new a-arms....no camber kit or a-arms....and if so should i get and alignment before or after the install of the camber kit, a-arms, wheels tires.??? in what order shall i complete my wheel tire upgrade. thanx and please no
Old Jul 24, 2003 | 02:38 PM
AcuraEL's Avatar
alignement as the last thing
Old Jul 24, 2003 | 02:41 PM
poison's Avatar
Default Re: alignment and camber ?? (HUBB)
I would recommend you install the new rims/tires and then go get an alignment and see if they are able to adjust if you have any negative camber.
It mainly depends on what your suspension set up is, if you have sway bars, coilovers/springs, how much you are dropped, that type of deal. Every car is different. If you have negative camber, that is easily fixed by adding washers to the trailing arm bolted to the sub frame.
As for the front, that can be adjusted by the lower control arm as well, but to an extent.
If you have over -3° of camber, then a camber kit would be needed in order to adust properly, but have the alignment shop give you the specs of the camber/toe adjustment and such.
Old Jul 24, 2003 | 10:08 PM
DCStreetHtch's Avatar
Default Re: alignment and camber ?? (poison)
well said by poison... if your **** is slammed then plan on getting a camber kit. In which youll need a camber adjustment and alignment!
-Bryan-
Old Jul 24, 2003 | 11:25 PM
eh2 nihonjin's Avatar
have an alignment done after you put everything suspension wise on including tires and wheels
Old Jul 26, 2003 | 02:57 PM
HUBB's Avatar
Default Re: alignment and camber ?? (eh2 nihonjin)
i have a 93 EG with TEIN SS. im planning on getting some 16's and ive been told i should get a camber kit installed frist and then get rims and tires that way i can have unlimited drop options ...true...how much does an alignment and camber adjustments usually cost..THANX
Old Jul 26, 2003 | 02:58 PM
HUBB's Avatar
i just dont want to be runnin around on new rims and tires with fucked alignment and camber wearing them out prematurely..i dunno
Old Jul 26, 2003 | 03:00 PM
HUBB's Avatar
my buddy says to just new a-arms which are the same or and the same price as camber kits and will leave me with better options for adjustments..? THANX
hatch_
Feb 10, 2009 09:25 PM
tduzzle
Suspension & Brakes
19
Jul 30, 2008 04:55 AM
BJA86
11
Sep 2, 2007 01:00 PM
E36 Guy
16
Apr 7, 2006 09:58 AM
BigDawwg6969
May 29, 2005 11:42 AM
