how long does the average OEM cat last?>
Old Jul 24, 2003 | 02:07 PM
jabroni95gsr's Avatar
Default how long does the average OEM cat last?>
i'm still on the original with 100k and a jrsc.
Old Jul 24, 2003 | 02:43 PM
Lord Helmet's Avatar
Default Re: how long does the average OEM cat last?> (jabroni95gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jabroni95gsr &raquo;</TD></TR><TR><TD CLASS="quote">i'm still on the original with 100k and a jrsc. </TD></TR></TABLE>
the rule of thumb is to replace it once it reaches 100k.
Old Jul 25, 2003 | 04:54 AM
JimBlake's Avatar
I've NEVER had to replace a cat.
'82 Rabbit 118k miles
'86 Jetta 147k
'89 Saab 220k
'95 GS-R 118k
my newer cars don't have enough miles to count...
It's easy enough to poison the catalyst early, tho. If you drive around for 6 months with a bad O2 sensor; or if you get something strange in your gasoline (too much sulpher?); run too rich or lots of misfiring & you can overheat it. Not all of those things are under your control.
Misfiring is bad. You have plenty of unburned fuel; plus there's unused O2 so the sensor thinks the engine's running lean. That can make the catalyst get REALLY hot.
Old Jul 27, 2003 | 02:43 PM
mattb16a1civic's Avatar
a cat will last forever if the engine is running properly
Old Jul 28, 2003 | 04:32 AM
jweller's Avatar
Default Re: (mattb16a1civic)
I just passed emissions with 120k on mine
Old Jul 28, 2003 | 06:32 AM
speedymon's Avatar
Default Re: (jweller)
Is it possible for the internals to rattle loose? My cat or something in that area is rattling like hell.
Old Jul 28, 2003 | 07:50 AM
JimBlake's Avatar
Default Re: (speedymon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedymon &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible for the internals to rattle loose? My cat or something in that area is rattling like hell. </TD></TR></TABLE>
Much more likely that's a loose heatshield. But it's possible. The monolith is made of ceramic, just ask anyone who's poked a hole thru it.
Old Jul 28, 2003 | 07:58 AM
raene's Avatar
Default Re: (JimBlake)
The ceramic can crack and leave bits rattling around in the cat. I should know, that's my problem and it's very annoying
I'm on my 3rd cat; I basically have to replace it once a year to get through AirCare... this year I had to go 1.5X oversized to get through. Very friggin' annoying, but I'm too eco-friendly to go test pipe...
rjmq06
Sep 12, 2010 03:05 PM
baiwldrnner
Honda Civic (2001 - 2005)
13
Jul 15, 2007 10:04 AM
MK4R34
Oct 10, 2005 03:29 PM
AllSpedup04
Oct 10, 2005 01:52 PM
Unlimitationz
May 11, 2005 11:16 PM
