Any last-minute tips on FastBrakes install?
Old Jul 24, 2003 | 01:25 PM
VTechie's Avatar
Default Any last-minute tips on FastBrakes install?
Tomorrow afternoon (and probably Saturday as well), I'll be doing the 11" upgrade at all four corners. I've already milled 0.060" from the caliper brakets to make the offset match up. I bought a set of four SpeedBleeders to make the bleeding no problem, I even have brake fluid ready.
I'm not sure what I'll wind up doing about the brake splash/dust shields, whether I'll bend, trim, or remove them completely.
Anybody with any experience?
Old Jul 24, 2003 | 01:31 PM
Fuuma0083's Avatar
Default Re: Any last-minute tips on FastBrakes install? (VTechie)
Did you get the Retainers for the brake pads?
I personally had to order retainers from a 99 Crv and then grind them down (like the brackets) to make them fit.
It would be a good idea to have a angle grinder handy (just incase you need to grind down some more)
And as for the dust cover you'll need to cut some of it off, not a big deal.
Good Luck
Old Jul 24, 2003 | 01:56 PM
VTechie's Avatar
Default Re: Any last-minute tips on FastBrakes install? (Fuuma0083)
I got the pad spring and retainers for a 98 Accord V6 (A&H Motorsports). It all seems to fit pretty well- I'll keep a dremel or grinder around just in case.
Thanks!
NazVil86
Dec 8, 2006 08:04 PM
t-rd
Jul 26, 2006 09:51 AM
Ohlias
Apr 27, 2003 09:57 PM
harryg
Feb 13, 2003 04:54 PM
el_Presidente
Feb 12, 2003 09:08 PM
