What do I need to drop in a h22a in my 89 rex.
Old Jul 24, 2003 | 12:17 PM
PRESTO-REX's Avatar
Default What do I need to drop in a h22a in my 89 rex.
Like I said before what do I need to drop in a h22a in my 89 rex. Some people say it would be easier to drop in a b-series engine. But if I have to use a little more money and I get way more power then why not but I want to get everything-staight before i buy anything .every bit of information would be greatly appriciated thank.
Old Jul 24, 2003 | 12:35 PM
SIRX's Avatar
Default Re: What do I need to drop in a h22a in my 89 rex. (PRESTO-REX)
Your search for h22 returned the following 28 results.
the search is your friend. archived topics crx/ef.
Good-luck also you might try searching in the hybrid forum.
IMO it's not worth it. You'll be a lot ahead by going with a B
Old Jul 24, 2003 | 12:42 PM
Crxer's Avatar
I guess its a good idea if youre only gonna drive in a straight line. Im pretty sure you have to mount the engine in a position that will make your axles funny (can't use stock axles btw). so you will probably break your axles really fast if you rip turns alot.
Old Jul 24, 2003 | 12:49 PM
silverCRXTC's Avatar
Default Re: What do I need to drop in a h22a in my 89 rex. (Crxer)
i always see this post but i never hear of anyone with a h22a rex wierd huh
Old Jul 24, 2003 | 01:12 PM
insanityworks's Avatar
why go with a h22a, when a b18c1 or c5 will out do a h22, its very hard to get them to fit, need custom axles, mounts, and then a whole lota suspension work, i had it done to my 89 crx, by a custom fabrication auto company, was great for straight line, but i rapped it around a pole as soon as i took it out on the street and went around a corner doing 45 mph, even with LSD ur tires spin due to weight transfer of the car
Old Jul 24, 2003 | 01:43 PM
thid92's Avatar
can I haz?
money
Old Jul 24, 2003 | 01:47 PM
t0eKnEe's Avatar
Default Re: (thid92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thid92 &raquo;</TD></TR><TR><TD CLASS="quote">money</TD></TR></TABLE>
and a 2nd car..
Old Jul 24, 2003 | 03:58 PM
MIRRAdekhtc's Avatar
Default Re: (t0eKnEe)
not to mention you would have to convert the car to hydrolic...
far as i know they never made h-series cable trannies..
Old Jul 24, 2003 | 04:50 PM
Timmah!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRESTO-REX &raquo;</TD></TR><TR><TD CLASS="quote">Like I said before what do I need to drop in a h22a in my 89 rex. Some people say it would be easier to drop in a b-series engine. But if I have to use a little more money and I get way more power then why not but I want to get everything-staight before i buy anything .every bit of information would be greatly appriciated thank. </TD></TR></TABLE>
A Prelude!!!
Old Jul 24, 2003 | 06:49 PM
88crxvtec's Avatar
Default Re: What do I need to drop in a h22a in my 89 rex. (azroth)
a Big Fuc*in Hammer!
Old Jul 24, 2003 | 06:56 PM
MR. ARIZONA's Avatar
Default Re: What do I need to drop in a h22a in my 89 rex. (88crxvtec)
I say go for it, why the hell not?
Old Jul 24, 2003 | 07:29 PM
Timmah!!'s Avatar
Default Re: What do I need to drop in a h22a in my 89 rex. (QUICKTEG)
Its almost saying "how do I put an SR20DET into a Yugo?" I will work, But it is a PITA. And not worth it.
Old Jul 24, 2003 | 09:26 PM
Mythos EF's Avatar
step #1
park car at ground level
step # 2
push engine hoist with engine up to 3rd floor of parking garage and hang over side
step # 3
release
Now either you'll end up with an h22 or a super rare 3.8L V8
seems easy and win win to me
either that or build your stock motor to prelude crushing power levels and laugh at yourself chimp boy
Old Jul 24, 2003 | 09:32 PM
miskone's Avatar
I plan to do the same thing and have not found any one that even makes mount for that. But I think who cares it will be worth it when i'm done at least i'll prove everyone wrong.
Old Jul 24, 2003 | 09:49 PM
Mythos EF's Avatar
Default Re: What do I need to drop in a h22a in my 89 rex. (miskone)
your not going to prove **** except this kind of attitude is ignorant when boku duckets are involved
For the price of the swap and custom fabrication alone you could build a turbo b16
Old Jul 24, 2003 | 10:00 PM
Racer613's Avatar
Default Re: What do I need to drop in a h22a in my 89 rex. (silverCRXTC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverCRXTC &raquo;</TD></TR><TR><TD CLASS="quote">i always see this post but i never hear of anyone with a h22a rex wierd huh
Dude..you must not be looking very hard...there is about 3-4 of us in here...somewhere. I have a 93 H22a in a 91 Crx Dx. I have just finalized alot of the little issues I was having..namely cooling...and the Raging Demon runs awesome now. As for corners....I turn pretty good, not as good as stock but pretty good. There is only 2 things to cut. 1 about 7-8" off the passenger side frame rail..and the hole for the shifter cables and shift linkage.
Place Racing makes a weld in mount housing kit and mounts to fit it....it works awesome..I can even close my stock hood! All those in here bad mouthing this swap need to see me in action...this car hauls some major ***....I beat the everloving **** out of a 1997 GSR Teggy...in 3rd gear!!!!!! (on digital camera!!!!!!!)
So read up and dont go on hearsay and the word of others...find out for yourself.....
see the process... http://www.collectiveracing.net crx/h22 woo wooo!!
Old Jul 24, 2003 | 11:18 PM
Aids333's Avatar
http://www.h22a.org
Old Jul 31, 2003 | 12:46 PM
2point6's Avatar
Default Re: What do I need to drop in a h22a in my 89 rex. (Aids333)
There is a lot of ignorance being stated in this thread. The swap is a bit more complicated... but can and has been done with great success. To all of you "bench racers" claiming that it yeilds poor results, STFU! You haven't any clue. Until you do it yourself, don't talk.
Old Jul 31, 2003 | 12:57 PM
Default Re: What do I need to drop in a h22a in my 89 rex. (2point6)
what tranny are you using? did you convert the car to hydro? how is this?
Old Jul 31, 2003 | 01:04 PM
2point6's Avatar
Default Re: What do I need to drop in a h22a in my 89 rex. (MIRRAdekhtc)
The tranny is a M2A4 (prelude) the manual to hydro conversion is handled by a Place Racing adapter. It works really well.
Old Jul 31, 2003 | 01:32 PM
keithv's Avatar
we don't need 2 active h22 in crx posts. the other one is more informative and less flamatory (is there such a word????).
joethejoeman
Sep 17, 2006 07:44 AM
OOSpyder85
May 25, 2006 09:17 AM
WhItE99CiViC
Oct 3, 2004 03:51 PM
Integra4Life89
May 4, 2004 12:42 PM
Noodles
Jan 1, 2003 11:20 AM
